Results 1 to 10 of 23
Thread: Weak engine under 2000 rpm - cdti 120
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    Default Weak engine under 2000 rpm - cdti 120
    Hello people. I have Just buy me a 2007 vectra cdti 120. I think its very litle torque under 2000 rpm, and then its "explode". I have checked for air leak but coldnt find any.
    I have monted a semi-blanking plate on the egr and cleaned this one and the boost sensor. I have also removed the trotle valve. But its still weak in low revs.
    Is it this way the cdti in vectra is? Or could something be wrong?
    Thanks for any answer.
    ket
    Sep 2009
    Audley STAFFS
    hello ket, max torque is at 2000 rpm, and it does come in with a bit of a thump, so I dont think there is anything wrong with your car, the 120 cdti I drove was the same its a heavy car for a 120 bhp, in fact my 1.8 petrol pulled better than the 120 cdti that I drove, just give it some foot, rgds ANT.
    Aug 2010
    North of Norway
    Thanks. It was appeasing to hear
    Sep 2009
    Audley STAFFS
    you might get a better reply than mine by puting your thread in the vectra chat section, rgds ANT.
    preston
    try
    new fuel filter,
    new air filter
    derestrict the airbox
    and then put some good fuel in
    i use shell V power
    oh and a remap will give you 180 bhp -----with gearing that just suits a remap....
    also check vacuum hoses and intercooler hoses
    Aug 2010
    North of Norway
    Thanks for tip. I have done those thing you write, except the remap. I have a problem finding the right file for my car. I have tried Medusa and two others, bot none have this file who match my car. I flash self with mo CMD.
    preston
    several uk companies do this
    perhaps contact them and see if they could do something remotely for you????
    i'd say you turbo should spin up at about 1200 and really come on about 16-1800.
    i try to keep my 150 at about 1800-2000 for best performance and overtaking ability
    what fuel are you using?
    Aug 2010
    North of Norway
    I am using normal Shell diesel. We dont have any opportunity then ordinary deisel here in Norway. There is not much power before 2000 rpm, but then it pull very vell.
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    Well, nothing extraordinary its not very strong engine. Better fuel will not give any visible difference (at least in mine) so u dont loose anything if u dont have it in Norway. I'll have to think bout some tuning box just need to make sure which one will be the best, maybe u should aswell.
    rgs
    preston
    the injectors will love V power
    but it just responds better on better fuel.....
    i'd remap as its adjusting parameters rather than just pushing more fuel through the system...
  1. vectra c 1.9 cdti 150 wont rev past 2000
    By safayth1993 in forum Troubleshooting
    Last Post: 4th January 2013, 20:08
  2. Emission light on, engine sounds rough and is weak
    By sjgore in forum Engine & Drivetrain
    Last Post: 3rd January 2011, 15:32
  3. Engine looses pawer at 2000 rpm
    By jacko52 in forum Engine & Drivetrain
    Last Post: 24th February 2009, 22:50
  4. Engine Judder 2.0 DTI at 2000 revs
    By cp123 in forum Engine & Drivetrain
    Last Post: 16th January 2008, 17:38
  5. Cdti Hesitation At 2000 Rpm
    By CRAIG in forum Engine & Drivetrain
    Last Post: 9th October 2006, 13:29
