Results 1 to 10 of 22
Thread: No lights on door switches?
    Oct 2010
    Lincoln
    Default No lights on door switches?
    Just bought a 56 plate 3.0 CDti and there is no lights on either the drivers or passenger door switches. All the switches work fine so should they be illuminated like the Astra is?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    yes they should be illuminated.
    Oct 2010
    Lincoln
    As I'm still waiting for the owners manual, I have no idea which fuse feeds them. Maybe it's blown so does anyone know which fuse feeds them (and what else would be missing if it's either blown or missing)?
    Engine : 2.2 Direct
    theres not a seperat fuse for that.. as they are all linked together via Gray/yellow wire., så rather check that it hasnt been removed from the plug.
    Does the interiur light come on when you open the door? (as it can be coding error on both DDM and PDM)
    Oct 2010
    Lincoln
    Yes the interior light comes on fine as does the dash when I open the door.
    Oct 2010
    Lincoln
    May be connected but I've just realised there is no cig lighter or ashtray illumination
    Quote Originally Posted by lencuff View Post
    If you've got an accessory socket (istead of a fag lighter) then you won't have any illumination around the socket or ashtray.
    Oct 2010
    Lincoln
    OK that makes sense, even though there is an ashtray there's no fag lighter itself just the socket so assume that's for SatNav etc. So back to why those door switches won't light up
    Correct. You won't be able to put a ciggy lighter in it either as the hole size is slightly smaller.
    Oct 2010
    Lincoln
    Thanks for that, I'll try the satnav 2moz. Didn't realize they were different sizes
  1. Passenger door switches
    By brianjamesreed in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2012, 19:57
  2. what smd's for the door switches?
    By Morephun in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2011, 14:58
  3. drivers door switches
    By Rickiw in forum Electrical & ICE (including SatNav)
    Last Post: 10th January 2010, 10:11
  4. Passenger door switches
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2008, 19:21
  5. Door Switches
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2008, 17:13
