Results 1 to 10 of 13
Thread: Weird one...help with signum
    Regular Member arkhan78's Avatar
    Nov 2007
    Leeds
    Default Weird one...help with signum
    Hi all
    well after changing the whole fron suspension, the springs, the shocks the arbs and the links i thought i would check the back, changed the rear shocks and now this one puzzles me.
    When i grab the rear driver side tyre at 12 & 6 oclock and pull it, it has about 1 to 2mm play? any ideas what could be causing this?
    I have tried tightening the nuts but it isnt the wheel....could it be the rear stablizer links? if so are they easy enough to change?
    anyway thanks in advance to any one that can shed light on this one.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Bushes on the back?
    Nov 2007
    Leeds
    which ones? the arb's have been changed....
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    It could be the outer bush in the arm (shaped like a banana) upper control arm.
    http://www.vectra-c.com/forum/showthread.php?t=46991
    its always 'mainly' only the outer bush (nearest the wheel) that goes, ive changed mine with ebay ones, but kept the old ones & may replace with the poly ones when they become available.
    Engine : 2.2 Direct
    Quote Originally Posted by arkhan78 View Post
    The rears ... you only changede the front as i read it.
    Nov 2007
    Leeds
    Quote Originally Posted by kenp View Post
    sorry yes, also changed the rear ones too
    Nov 2007
    Leeds
    Quote Originally Posted by the-wizard View Post
    nice one mate, ill have to give this a whirl this weekend! easy job?
    Engine : 2.2 Direct
    or god help it.. the well bearings in the rear hub...
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    No its a pig!, the inner bolts are very akward to get at the n/s are harder than the o/s, & I had a pit to do them over.
    Regular Member Jezzy's Avatar
    S.E
    Only a few bolts to undo, but access to the inner ones is a bit restricted and the bolts are quite tightly done up, that's what makes it an awkward job.
  1. signum intermittent blue smoke and weird temp gauge
    By kevsmit in forum Engine & Drivetrain
    Last Post: 9th July 2012, 18:54
  2. signum intermittent blue smoke and weird temp gauge
    By kevsmit in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 21:08
  3. Weird Signum Seats
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2011, 22:23
  4. Signum Heated Rear Window Fault - WEIRD !
    By Signumv6man in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2008, 19:21
