Thread: Is my cam belt fitted ok
    Regular Member big nath's Avatar
    Jan 2008
    Irthlingborough
    Default Is my cam belt fitted ok
    Had my cambelt changed last week as the water pump was leaking so for the second time had new cambelt kit done. Had work done at a local garage as been recommend to me, so my question is how will I know if it's been done properly as years ago had a cambelt done on my old vectra b and fitted wrong and the engine blown up ? Will it sound ruff or drive different.
    Car is 1.9 cdti 150 16v 2004 hatch.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    yes probably louder diesel clater and poor starting. Worst BANG
    Jan 2008
    Irthlingborough
    If I got it plugged into a tech 2 would they know if working right as going to see if there is any updates for my cars ecu ?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    probably not! The only 1 sure fire way is to check the belts timing & tension, but surley you would have taken it to somewhere you were happy about them doing it?, checking the job isnt that much work but a sealy locking kit would prove it for sure!.
    Jan 2008
    Irthlingborough
    Found a water leak so had to get into garage asap as needed car back next day as family going away for week . And this small garage did go out off his way to find falty water pump and fix it the same day. Told him to fit new cambelt kit at same time as 30,000 miles since last belt change, done about 500 miles since fitted, probable just me being paranoid.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    you dont seem to be having much luck with water pumps!, If they didn't put sealant round the bolt threads & a little on the studs, then the pump will leak!,
  1. Fan belt / Drive belt
    By patdavis in forum Engine & Drivetrain
    Last Post: 8th January 2011, 00:39
  2. Should I pay for new cam and time belt to be fitted while engine in bits?
    By neverton in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2010, 11:51
  3. Vibration after new Crankshaft pulley and belt fitted.
    By stroake in forum Engine & Drivetrain
    Last Post: 14th December 2009, 18:36
  4. drive belt or fan belt
    By geebee007 in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2008, 10:23
  5. Fitted for 314mm discs but fitted with 304mm discs
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 13:19
