Thread: LMF 314mm kit with 16inch steel rims
    Full Member
    Nov 2009
    Milton Keynes
    confused LMF 314mm kit with 16inch steel rims
    Hi Guys
    - anyone fitted the 314mm disc/calliper combination with 16inch steels?
    cheers Mart
    They fit with the 16" spare wheel as it comes as standard with the V6 engines like all the other engines. I'd expect they would, might be best seeing if you can get someone to find out for you...
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I have the 314mm brakes and 17" wheels and I would say that 16" would fit but tight. I would worry about the stick on balanceing weight though unless you have steel wheel which you will be ok ( I think )
    Regular Member david.aka.judas's Avatar
    Suffolk
    lmf say.....
    314mm brake upgrade for the Vectra C and Signum.
    This kit contains 314mm ventilated discs, calipers and brake pads.
    Minimum 16" wheel diameter required.
    good luck trying to find a complete new set though.
    preston
    lmf can't supply 314mm
    try neo brothers on web
    or go to scrap dealers and find 04-05 V6
    Full Member
    Nov 2009
    Milton Keynes
    Brilliant looks like a goer then - thanks guys
    Sorry didn't do a good job of explaining myself - already got the discs, just trying to sort out a set of winter tyres on 16-inch rims. With the 18 inch boots/potenzas I can't even get-up the road!
    cheers MM
    preston
    buy some snow boots
    thats what i'm doing
    last winter was a lesson the the vectra;s lack of ability in the snow.
    and i've driven in snow every year for 25 years
    shame really , you'd think it would cope better
    Suffolk
    Quote Originally Posted by Mandarin Mart View Post
    cheers MM
    thats great - good idea, perfect for saving the alloys over the bad months.
  1. For Sale: Winter Tyres on 16 inch steel rims (Set or 4)
    By luke4487 in forum Parts for sale
    Last Post: 15th February 2012, 20:07
  2. steel wheels and 314mm brakes
    By 2.2 oil burner in forum Suspension, Wheels & Brakes
    Last Post: 15th November 2011, 18:31
  3. 17" steel rims to fit Signum 1.9 cdti
    By Maxkristian in forum Suspension, Wheels & Brakes
    Last Post: 19th November 2010, 00:09
  4. Steel Rims
    By snowball1 in forum Suspension, Wheels & Brakes
    Last Post: 16th October 2009, 21:46
  5. Astra Steel rims
    By kitchpoo in forum Parts for sale
    Last Post: 20th November 2005, 22:47
