Thread: diesel filter replacement
    Oct 2010
    CHESHIRE
    Default diesel filter replacement
    i havce replaced the diesel filter on my vectra 03 model dti now i cant get it to start and help would be great thanks
    i have tried filling the housing and then trying to start and still nothing
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    it takes a few cranks mate, or try loosening inj pipe1 to bleed
    Oct 2010
    CHESHIRE
    which is no 1 injector
    Oct 2010
    CHESHIRE
    tried cranking sevral times and it still wouldnt start checked filter tried old 1 again still wouldnt start so put the new 1 back in
    Jan 2008
    Dundee
    If it doesnt start easily when you try the injector trick get someone to give you a tow, get up to around 15 mph and put the car into 2nd gear and that should do the trick. It shouldnt take long to start that way.
    Aug 2009
    n ireland
    i have the same problem every time i change mine and it is always the top of the filter bowl is,nt fitted properly it needs to be lined up with the plastic bit that sticks up from the bottom part ,i no you will be convinced it is fitted properly but try removing it and be sure it is lined up with the bit on the base of the bowl ,i always make sure but still no go first time worth a try if still not sorted.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    fill the pipes up and housing every time with diesel or it will never start cause no scavenge pump
    north east
    Key in move to position 2, key out do this 4 / 5 times then try start it.
    Engine : 1.9 CDTi
    Quote Originally Posted by roswell View Post
    That only works with the CDTi as they have an electric pump.
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. Air Filter replacement
    By jja66uk in forum Engine & Drivetrain
    Last Post: 30th June 2011, 20:51
  3. Air Filter Replacement.....
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2007, 21:20
  4. Diesel filter replacement 1.9 cdti 150
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2007, 00:52
  5. Air Filter replacement
    By pazzazzz in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2007, 18:21
