Thread: 2.0 Turbo Rear Brake Pad issue
    Regular Member a1ant's Avatar
    Jul 2010
    England
    Vehicle : 2.0 Turbo
    Engine : 2.0 Turbo
    Default 2.0 Turbo Rear Brake Pad issue
    Hi all,
    I have been suffering from an annoying rattle/knocking noise from the rear drivers side of the car. I've had it for a few months and thought I had tried everything. I checked all the suspension for worn bushes/drop links etc. I even removed the rear bumper thinking it may be something loose under there
    Well today I have FINALLY found the cause. On the rear drivers side, the inner most pad is rattling around and jumping about when the disk is turning. I have looked in the guides section on here and see that the GSi has a spring clip on the rear of the pad that clips around the calliper piston to hold the pad.
    My question is, can anyone confirm if the 2.0 Turbo SRi should also have this spring clip? And if so, is the only option a set of new pads that this time HAVE the spring clip on the back?
    Many thanks in advance,
    Alan
    Regular Member signumturbo04's Avatar
    SCOTLAND
    yes the rear pad (piston side) has a metal spring clip. my 2.0t signum has anyway lol
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    yes mate, there is a newer set of pads available with the clip.. dealers will seel them and mintex versions are available on ebay.
    Jul 2010
    England
    Vehicle : 2.0 Turbo
    Engine : 2.0 Turbo
    Thanks for the replys!!
    Ive seen two types of clips ....
    And then these:
    The bottom set have the spring clip on the top, as opposed to on the rear
    Any one seen the second type? I cant see how it would work myself.
    Many thanks,
    Alan
    Jun 2009
    South Coast
    the second 2nd set are the ones you need
    Jul 2010
    England
    Vehicle : 2.0 Turbo
    Engine : 2.0 Turbo
    Brilliant! Thanks!
    Just ordering them now. What oil do you recommend for the 2.0 Turbo? 0w30 or 5w30?
    Thanks again,
    Alan
    Jun 2009
    South Coast
    i use 5/30 fully synth castrol
    Jul 2010
    England
    Vehicle : 2.0 Turbo
    Engine : 2.0 Turbo
    Thanks Nige your a star!
    Alan
  1. Vectra c turbo rear brake caliper tool
    By davedave in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2013, 18:35
  2. Turbo issue
    By kman247 in forum Engine & Drivetrain
    Last Post: 25th September 2011, 20:49
  3. CDTi 150 Turbo issue !!
    By mark_647 in forum Engine & Drivetrain
    Last Post: 28th June 2009, 18:08
  4. Turbo issue???
    By duncatr in forum Engine & Drivetrain
    Last Post: 23rd December 2008, 14:10
  5. Turbo issue on 1.9 CDTI 120
    By RichieClyde in forum Engine & Drivetrain
    Last Post: 9th July 2008, 09:39
