Thread: Dashboard strip
    Oct 2010
    glasgow
    Default Dashboard strip
    Hello guys,
    I wanted to ask if its possible to pop out the chrome strip that is present in the dashboard strip that goes across the face of the dashboard.
    Reason being, I currently have the walnut effect one, and i have sourced a strip that is matt silver/grey but also has a kind of chrome inlay strip, if that makes any sense at all!
    If you could help that would be great!
    Mo
    Regular Member Craig1985's Avatar
    harwich essex
    The one between glove box and airbag? If so it just pulls/clips off
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Yes it comes off quite easy. remove the fuse box cover on the end of the passenger side of dash board than carefully, using a wide blade flat screwdriver and rag gently prise it off. Its only held on by 4 spring clips.
    Jul 2009
    The Rift, Cardiff
    It just pops off, open the glove box and pull from under the strip, there's maybe 4 clips. The strip with the chrome bit is off a facelift I think.
    Edit; beaten to it
    Administrator plasma's Avatar
    On the Forum
    369 Post(s)
    Engine : 150
    Mileage : 74000
    It wont fit your one properly, if you look at the new one it bows outwards towards the right hand end because the dash is different on the facelift.
    Oct 2010
    glasgow
    Dammit! Its an 06 plate so yea i guess its the facelift model was on to a bit of a bargain there as well!
    Oct 2010
    glasgow
    Would anyone know if the walnut strips on the door cards come off just like the one on the dashboard? I have tried but its not happening, dont want to pull it off to find it screwed in from the back or something!
    11 Post(s)
    IIRC, they're held from behind with those star type washers that are pushed onto stems which are attached to the trim. You need to remove the door card, and prise off the retaining star washers.
  1. Dashboard Trim strip.
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 23:18
  2. dashboard bit
    By porthy-t in forum Styling
    Last Post: 19th January 2010, 19:18
  3. Left Dashboard Chrome strip removal ?
    By 67688c in forum General Chat
    Last Post: 2nd December 2008, 18:03
  4. Marble in my dashboard ?
    By 742-xx in forum Suspension, Wheels & Brakes
    Last Post: 7th July 2007, 12:49
