Results 1 to 10 of 15
Thread: 1.9 cdti auto, conversion to man gearbox
    Kent
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default 1.9 cdti auto, conversion to man gearbox
    Hello all.
    right got a little bit of work todo but wanted to check whats needed in doing this conversion.
    the reason for it being down is the auto box is screwed fitted a new one and thats screwed as well.
    no i know i need the following but have i missed any thing.
    gearbox
    flywheel
    clutch
    gearbox mounts front and back
    clutch hydrolic piping
    clutch slave
    clutch pedal and brake pedal
    im guessing the drive shafs arthe same.
    also is there any ecu's that need to be changed?
    and does any one know which wire is on the loom to the selecter unit that does the starting ie confirm its in park?
    Aug 2010
    Leeds
    It's not worth the hassle just go buy a manual.
    Far too much work to do to convert.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    i think you would need the ecu reprograming as well
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    As already suggested, conversion is gonna be extremely labour intensive and costly...
    If it was me, I'd be getting shot of the gearbox fubar car and buying another, or I might consider buying up a same colour good running but panel/crash damaged vec and using the old vec for spare parts/panels..
    Regular Member Turbomanrony's Avatar
    Sep 2010
    LEEDS
    if its the 1.9cdti 8v i have most of the bits 4 you just no gearbox .
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    sell auto but manual you will find it so much hard work to change it
    Kent
    Trim : SRI
    cheers all for the comments, the option to do it or not is not there.
    the cars already striped of its gearbox, im just needing the list to make sure i have every thing from the breakers in one trip so i can complete the work with out having to keep going back for the parts
    Are you VXR Enough
    13 Post(s)
    dont forget this
    Kent
    Trim : SRI
    dont forget this
    What needs reprograming, as in what needs to be changed on the ecu?
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Gear lever
    Cables.
    Centre Console
    Possibly new Dash
    Wiring Loom as no Auto Box to connect to
    As said Probably ECU as will not detect Auto Box
    Driveshafts Maybe
    AS somenone said b4 Ricky seems to be more hassle than its worth,but i can see why your doing it. but good luck
  1. v6 cdti auto gearbox sensor
    By porkaboy in forum Engine & Drivetrain
    Last Post: 2nd October 2010, 11:25
  2. Gearbox oil for CDTi 150 auto ??
    By Signumcdti in forum Engine & Drivetrain
    Last Post: 27th June 2010, 21:59
  3. 1.9 Vectra cDTi auto Gearbox problem
    By matthunter76 in forum Engine & Drivetrain
    Last Post: 23rd September 2009, 13:53
  4. 150 cdti auto engine and gearbox software
    By veralum in forum Engine & Drivetrain
    Last Post: 16th September 2009, 18:46
  5. 3.0 v6 cdti 20005 auto gearbox problem
    By nte01 in forum Engine & Drivetrain
    Last Post: 22nd March 2009, 02:06
