Thread: Air conditioning problem
    France
    Default Air conditioning problem
    The dual zone air conditioning is not working. The same T was set for auto mode (ex. 22C) on both sides, then the right part blows hot air while the left - cold. It looks like the right (if separate) T sensor gives wrong signal to the ECU. Then the ECU gets crazy - going from very hot to very cold, i.e no regulation at all.
    Any idea where is this sensor or how can it be checked (measured)? Thank you in advance.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    I know there are 2 sensors, and think to recall that they are behind the heaterpanel.. (all the way back).
    France
    Do I have to remove all decorative strips, etc. ? Could it be some other problem (not the sensors) to this funny air conditioning right/left different behavior?
    Engine : 2.2 Direct
    no just the ECC panel and the cubbyhole.., you should be abel to see them plugged in the the "white" box.
    France
    Sorry, do you have some pictures of this ECC and the cubbyhole (removed or dismounted)?
  1. air conditioning
    By marko1973 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2011, 21:37
  2. Weird Air Conditioning problem?
    By PhilDunford in forum Vectra C / Signum Troubleshooting
    Last Post: 8th June 2009, 15:02
  3. Air conditioning problem!!!!!!!
    By Fedex in forum Bodywork & Interior
    Last Post: 16th February 2009, 17:18
  4. air conditioning fan??
    By alexander08 in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2008, 15:47
  5. Air conditioning
    By cbee101 in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2008, 14:44
