Results 1 to 10 of 15
Thread: steering knock
    Glasgow
    Default steering knock
    right guys,
    what does it mean when you are sitting still in the car and move the steering left and right and get a knocking noise on each turn?
    im hoping its not the steering rack!
    their also feels a little play in the steering ..
    Chelmsford
    Does it happen with the engine off?
    If it does, it's probably the universal joint on the steering column, the one on my old Vec B had worn, so it made a clunk when you wiggled the wheel left and right.
    Or do you mean it's clunking as you rotate the wheel completely?
    Glasgow
    I've not tried it with the engine off. But its just when I turn the steering wheel. I was hoping it would be that. I just. thought I would see what you guys thought first.
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    hj mate..were the column attaches to the rack there is a 10mm bolt head on the uni joint just nip it up.... may only take less than 1/4 of a turn..better done when engine cool!!!!!!!!!!! HTH
    Glasgow
    would that cause the free play i feel?
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    almost certainly.... did my friends 57 plate sri about 2 weeks ago
    East Midlands
    ??Strut top bearing...place your hand on the strut top ,and get a mate to turn steering wheel, you'll feel it if it's the bearing gone,easy ish job to do.
    Glasgow
    both bearing where changed less than a year ago...
    Aug 2010
    Derbyshire
    Quote Originally Posted by big tee View Post
    Well the problems described by the OP were exactly what I was experiencing for around ten days.
    All of a sudden the steering seemed to have play when moving the steering wheel side to side.
    Yes it was the pinch bolt on the bottom of the column that needed nipping up, job done and all play gone!
    Glad I searched through the forum looking for a fix
    So if your steering feels a little loose try the above first, nothing to loose.
    Mick
    Dec 2010
    Driffield
    Quote Originally Posted by macdad View Post
    I feel sure the top bearings on my Vecy have gone, just like you say macdad. question is , can i get away with just replacing the bearing or should i replace the whole top fitting, at much more expense.??
  1. knock from steering
    By marktaylor in forum Vectra C / Signum Troubleshooting
    Last Post: 4th July 2012, 08:53
  2. Steering knock....suggestions???
    By Stevie76 in forum Suspension, Wheels & Brakes
    Last Post: 26th February 2012, 21:27
  3. knock on steering help ?
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2009, 20:18
  4. Steering knock sorted!!
    By shrekster in forum Suspension, Wheels & Brakes
    Last Post: 20th March 2009, 14:35
  5. Knock Knock Knockin on heavens door
    By lizard in forum Engine & Drivetrain
    Last Post: 17th January 2009, 00:10
vectra c knocking steering rack
