Thread: How do I remove a House Radiator with a Room Stat
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Default How do I remove a House Radiator with a Room Stat
    FOlks,
    Urgently need to know how I can remove a radiator from a wall, with one side controlled by a room stat.
    How do I know when the valve is closed so that no more water comes through?
    Thanks.
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    Valve closed is normally fully turned clockwise on pretty much anything, or am I not reading your question right ?
    Regular Member leonvectrac's Avatar
    south shields
    turn the room valve to zero or past zero that should stop water and other valve on other side then thats it if im reading correct
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    all you need to do is turn the trv off to number 0 or a frost type thing and with the lockshield side , take the cap off and get a spanner or simmilar and turn it clockwise until it will turn no more , then you can either put a bowl or something under the nut nearest to the rad to drain it mate
    when i say trv i mean what you are calling a room stat mate
    Chelmsford
    Do as above and with the central heating running, open the bleed valve. If no air or water flows out, then the rad is isolated and you can just take a wrench to it.
    Just be careful not to do as I did the other day and put too much strain on the joint between the pipe-work and the valve. The valve on our bathroom rad was seized tight and developed a leak in the compression fit when I tried to undo it. Ended up having to drain half the system to fit a new valve!
    Good luck!
    Birmingham
    Nice one chaps. Will give it a go today. Thanx.
    if its the adjustable stat on the radiator it should have come with a grey cap , you undo the screw holding the stat on and remove it then screw the grey cap down where the stat was and this shuts off the valve
  1. Intercooler radiator removal without water radiator
    By Whosane in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2012, 15:48
  2. changed stat then ...
    By gsxrster in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2011, 03:39
  3. will this stat fit?
    Last Post: 20th January 2011, 16:14
  4. How do I get to the 'stat on a Vectra C?
    By heraldsteve in forum Engine & Drivetrain
    Last Post: 24th November 2010, 23:32
remove vectra c radiator
