Results 1 to 10 of 13
Thread: Misfire on wifes Rover 200
    Catterick, North Yorkshire
    Default Misfire on wifes Rover 200
    Hi all the wifes T Reg Rover 200 has got a misfire when idling, seems to go away above 2500 rpm, i have changed the plugs, plug leads, dizzy cap and rotor arm, had the injectors out and cleaned them and the crank sensor on gearbox but still has a misfire anyone got any ideas for other things to check before i scrap the thing
    Mileage : 000
    What about the spark plugs don,t overlook them. We had a simaler thing on my dads VW Polo. Several years ago.
    Quote Originally Posted by ed taylor View Post
    As above mate put new plugs and plug leads in already.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    scrap it... lol I had an N reg 1.6 rover 200 and had the same problem. Wouldnt start and needed all the ignition set replacing as you did. Then one day the engine went as i was taking a corner at night... lights off, power steering and brakes gone...
    I wouldnt recommend that car to anyone... although saying that I sold it 'as dead' to some portugese on ebay and got a parking ticket through a few months later lmao!
    Mileage : 000
    Quote Originally Posted by Fearns View Post
    Yes that mybe the case I put new plugs in the Polo. But they were not "compatable" so to speak, when a different brand were fitted the car ran perfectly. Might be worth trying a different set, just in case.
    Mileage : 000
    Might even be the head gasket. Have you ruled that out. If yours is the K series engine they were reknown for the head gasket going.
    Worcs/Staffs/Westmids (ish)
    If it's got more than 35k miles on the clock the head gasket has probably gone
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    Could be a failing coil, weak sparks and all that ..
    Glasgow
    Definetly the head gasket ive had a few rover 200's and once its gone the car will never be the same.
    Oily coolant, water leaks, rough idle or hesitation when driving means HGF.
    Bristol
    I really can't see why people slag these cars off so much. Yes the K series had its HGF problems, but if looked after its a good car and a great engine.
    We've had the 214 with k series engine for over 4 years now and it's only let us down once when the dizzy contacts disintegrated! It's now on over 93k miles!
    If you'd like the coil pack, I have one lying around which I can send over if you'd like.
  1. where`s the rover???
    By VEC-MAN in forum General Chat
    Last Post: 18th December 2008, 20:12
  2. Will Vauxhall 'do a Rover'?
    By Deadman in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2008, 11:32
  3. Replies: 1
    Last Post: 21st January 2008, 23:33
  4. MG Rover Question
    By D-S-Dave in forum General Chat
    Last Post: 7th January 2008, 14:17
  5. WOW!! Not your average rover
    By pricey in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2007, 12:29
