Thread: cant open the bonnet
    Full Member chunkster's Avatar
    North east HQ
    Thumbs up cant open the bonnet
    evening chaps, it seems i cant open the bonnet using the handle under the dash. Is there another way to release the catch without havin to take the bottom covers off and trying to reach through with a long stick??
    any idea's?
    Wayne -
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    If the cable is still attached, just loose - pull the handle as far as you can, then get a pair of pliers on the cable and pull.
    Once the bonnet has popped... adjust the cable !
    Full Member paul.sessions's Avatar
    leighton buzzard
    crowbar
    Regular Member Keif's Avatar
    In the Garage
    Try and release it with someone pushing down on the bonnet.
    Then try what Handyandy-UK suggested. (won't hurt if someone is pushing down on the bonnet)
    If not it's the stick time.
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    Jul 2009
    The Rift, Cardiff
    Sometimes after pulling the lever the bonnet wont open and I have to push it down then try again. It might work if you have someone else to pull the lever while you push down and pull up on the bonnet.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    If you have too much 'slack' in the cable IE the handle pulls a fair way back before it seems to do anything, Then when you eventually get it open, undo the screw that holds the outer cable shown in pic, pull back on the outer cable to take up the slack - retighten the clamp screw, then you will have a 'full' pull on the handle again.
    May 2008
    Derbyshire (south)
    Just had to adjust mine for the same reason. someone pushing on the bonnet(lightly) while you pull the lever should work, but failing that, yes a pair of pliers to pull the cable, as suggested, but try not to squeeze it too much, or it will never slide right again. Once under the bonnet & adjusted, get some vaseline onto the spring/clip too.
    Jul 2009
    The Rift, Cardiff
    Sod's law; my bonnet wouldn't open today. I eventualy got it open by holding the leaves fully open with a pair of pliers then went round and lifted the bonnet.
    Did what The-Wizard said above, works every time now
    stockport
    Arrow
    Quote Originally Posted by chunkster View Post
    any idea's?
    WELL.........Did you get it open in the end???????.We're all stood here holding our breath wondering how it all turned out?.FELIXX.
  1. Bonnet won’t open!!
    By Badger59 in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2013, 17:18
  2. Bonnet won't open!
    By mohojo in forum Engine & Drivetrain
    Last Post: 8th July 2010, 01:05
  3. bonnet open at 50
    By willoftoon in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2009, 18:50
  4. cannot open bonnet
    By tjsingh in forum Bodywork & Interior
    Last Post: 11th December 2007, 19:13
  5. cant get my bonnet open
    By cow monkey in forum Bodywork & Interior
    Last Post: 8th October 2007, 19:11
