Thread: Decat questions
    Regular Member Mike Boden's Avatar
    Sep 2010
    Prestatyn
    Default Decat questions
    I'm finally getting my exhaust fitted by Powerflow on Thursday and i'm thinking of having the cat taken out too. From what i've read this won't affect the MOT but will I be left with any warning lights on the dash because of this removal? Also, what effects should I expect to see from this?
    Thanks!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    No dash lights at all and you should see a slighly better pick up. Needs to be combined with a remap to make the most of it
    Sep 2010
    Prestatyn
    Ok cheers mate, mine was remapped by Vauxhall VXR apparently when new! Hopefully see a bit of a difference then!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quite possible it was re-mapped by triple eight buddy.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    de-cat on a diesel is all good imo, MOT is soot particle test only, also if you only have a centre section fitted then the noise should be great too....
    Midlands Mod Shop - NFFC.
    Sep 2010
    Prestatyn
    Cheers guys! At the risk of sounding dumb, which part is the centre section? Is this before the cat?
    Trim : Get a
    you will have the cat then centre section then back box on any standard 1.9 cdti system, the cat is after the manifold so removal is as easy as pie.......
  1. 2.8 / vxr decat
    By Ziggy in forum Petrol Engine related
    Last Post: 12th June 2012, 21:43
  2. 2.0 dti decat help?
    By kieronlee in forum Diesel Engine related
    Last Post: 2nd April 2011, 19:54
  3. 2.0 dti decat
    Last Post: 28th March 2011, 10:21
  4. to decat or not to decat a gsi - is it worth it?
    By TimTay in forum Petrol Engine related
    Last Post: 21st January 2011, 21:25
  5. What next-decat or K&nN ?
    By Fash in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2010, 20:16
