Thread: Random thuds for no reason!!!
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default Random thuds for no reason!!!
    As i drive along even on smooth roads so i know its not suspention every now and again i hear a thud like some kids av thrown a brick at my car.. Sounds like its comin from boot area or passenger side, but every time it happens i jump out of mi skin and brake as i think ive run sumone over or sumones bricked mi car! Wierd i know but any ideas??? Ta
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    Broken spring maybe ? If coils snapped I would assume it could make noises even on smooth roads if the two bits keep twanging against eachother..
    Sodding Typical on Sea
    Sounds like it could be a spring as that would cause the kind of sound your describing. How is the ride height side to side?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Look at & feel the bottom last coil/piggy tail on the rears!, there common for snapping,
    Sep 2010
    Leeds
    No springs are fine they are apex anyway so not standard due to standard ones snapping! Its more of a deeper noise than a spring more of a thud
    Dunstable
    ARB drop links or bushes? Had this on my preface, loud clonk as I drove round....very annoying
    preston
    would agree with above
    also check wheel nuts....a friend had this very sporadic problem and it turned out to be a ever so slightly loose nut
    north east
    wrap a piece of insulation tape around the post that the boot latch clicks round to rule that out.
  1. The only reason I bought a PS3
    By rushy in forum Games Room
    Last Post: 6th May 2010, 07:03
  2. is this the reason?
    By twaiter in forum Styling
    Last Post: 21st August 2009, 19:51
  3. new reason to get the wife to
    By Lump in forum The 'Off Topic' room
    Last Post: 15th June 2009, 22:24
  4. No other reason
    Last Post: 29th March 2009, 10:31
  5. What was the reason for.....
    By m_r_shaw in forum The 'Off Topic' room
    Last Post: 8th January 2009, 22:44
