Thread: rear pads
    Sep 2010
    liverpoool
    Default rear pads
    i recently replaced the rear pads on my 06 vectra (life).and i put them on the same way the old ones were fitted. i started to get a noise from n/s/r/wheel, and thought it was the bearings . got the AA out to check them, and the guy has stated its the pads rattling as they are on the wrong way round. does the pad with the spring attached go on the inside next to the piston, or on the outside.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    inside mate
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    when i replaced mine i replaced them as they came off but when i done the otherside it was different the spring was on the wrong way on the nsr,
    when you press the pedal then the spring goes over the piston ,well mine did anyway
    Sep 2010
    liverpoool
    hmmmm the AA guy says the one with the little spring on top goes on the outside of the disc. and the other plain one goes next to piston, and the 2 little studs fit into the indents on the piston.
    Nov 2009
    south wales,Cwmbran
    well i think the AA man is wrong coz i also thought the same thing that the studs on the pads go into the holes,
    but there is a difference in size imo.
    i could be wrong mcker as i owned a cdti 150
    Sep 2010
    liverpoool
    myelite150 you talkin about the rear pads that have the 3 rings on the back, or the ones with just a small spring on the top of them.
  1. which rear pads for a 3.2?
    By andyxedos in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2011, 19:05
  2. Rear pads
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2010, 16:14
  3. Rear pads
    By Daywalker in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 07:29
  4. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
  5. Rear Pads
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2007, 18:02
