Thread: Oil on under tray
    Sep 2009
    Glasgow
    Default Oil on under tray
    Hi all was looking at the jacking points and noticed oil on the undertray on the nearside of the car dosn't look like it's been dripping but it is covered with oil, I have placed 4 a4 sheets of paper stuck together underneath this patch of oil on undertray to see if anything is dripping, i'm thinking it has been garage when doing service missing filling hole and it has leaked down onto undertray (i hope) as there is oil residue to the right of the filler hole.
    Regular Member Exclusive BV's Avatar
    West Midlands
    What colour is the oil?
    Does it look fresh like honey or does it look like blacker (leaking) oil?
    Sep 2009
    Glasgow
    it's black old oil, just looked out the window and the paper i put down to see if there were any drips has blown accross street even with stones as weights., will check road when i move car tommorrow, check oil every week and the hasn't budged for months, looks like the oil has been there a while first i've really looked under the front of the car since i got it just over a year ago.
    Sodding Typical on Sea
    I had this effect with a Passat once when the garage must have spilt oil during a service. The car was dripping oil for weeks while I thought it best to let it run off naturally, eventually it caused so much mess I had to remove the tray and it was then I got about another litre plus of spent engine oil!
    Sep 2009
    Glasgow
    yep i hope that's what happened, will check road under car tommorrow. and when I get a chance to jack car up on axel stands will check the undertray
    Regular Member Jezzy's Avatar
    S.E
    Clean it off if you can get enough access, that way it's easier to tell if it returns.
    Sep 2009
    Glasgow
    good point mate ! should have thought of that one.
  1. Aux In Tray
    By hodge725 in forum Electrical & ICE (including SatNav)
    Last Post: 30th September 2012, 22:15
  2. under tray
    By temprahater in forum Engine & Drivetrain
    Last Post: 11th October 2010, 17:43
  3. Tray Up
    By AJA in forum Comedy & Humour
    Last Post: 22nd February 2007, 09:33
