Thread: axel stands
    Sep 2009
    Glasgow
    Default axel stands
    Got the pair from lidl good price, are thes ok for the vectra, and what is the best way to use them, should i jack up from the front, if so where is the safe kacking point.
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    Quote Originally Posted by nokiaman1978 View Post
    pmsl well mucker if it falls off the axle stands you can KACK yourself anywhere you want .
    personaly i would do it there and then (sorry mucker couldnt help myself)
    i press the wrong key all the time and spell bad
    but to answer your question i usually get a block of wood on them first and either use the recommended jack points or across the front sill by the wheel arch
    Sep 2009
    Glasgow
    lol
    Nov 2009
    south wales,Cwmbran
    just searched this might help mucker
    http://axlestands.net/axle-stands/ho...e-axle-stands/
    Sep 2009
    Glasgow
    cheers mate, already seen that site looking for help on the vec for best position
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    I think the best place to put the stand are on the specific jacks points (the square holes) I think people cut a block of wood that fits in the hole so that axle stand rests flat on the wood.
    yep, I too got a 7.99 set from lidls today, just for when and if I might ever need them.. I initially picked up two boxes of pairs, but then after a while decided to just buy one pair, thinking would I ever need to put my car up on four axle stands?? Is it even safe to do so? Does anybody put a car up on axle stands all round?
    Regular Member Jezzy's Avatar
    S.E
    If you're using a trolley jack to lift the car then position it next to the standard jacking point, where's there's a flat section of chassis. Don't use the jacking point itself (except when using the Vec's own jack), even with a piece of wood inserted into the rectangular slot, as the wood can crack easilly. Once the car is supported by the trolley jack, you obviously want the axle stands to be positioned a little bit away from the jack otherwise they'll just get in the way of each other. Whether it's the front or the back, look under the corner you're lifting and you'll see strong rectangular box sections of chassis - put the axle stand under one of those.
  1. Where to put axel/jack stands?
    By hkp_octb in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2010, 14:49
  2. axle stands
    By liam2.0dti in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2009, 23:23
  3. Anyone know what ECOTEC stands for?
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2009, 22:20
  4. axel weight and lowering springs
    By animal22 in forum Suspension, Wheels & Brakes
    Last Post: 23rd April 2009, 04:48
  5. Where do you think he stands?
    By Stevel in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 22:34
