Thread: Jumped a tooth?
    Oct 2010
    scotland
    Default Jumped a tooth?
    i have a 53 plate 2.2 sri dti vectra
    car conked out a while back and had 2 mechanics look at it
    lastest one says he cant tell for sure whats wrong
    my question is this if my engine jumped a tooth while being driven would you notice it?
    and if it did what kind of damage would it cause??
    car drove fine no splutters just conked out and wont start again, someone thinks it might just be crankshaft sensor (because of the code it threw up) that need changing but for some reason garage wants to strip down the engine to have a look, would it not make more sense to just change sensor and see if its that to start off with?
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    YES!, ideally you need someone in your area with op-com!, if the sensor threw up a light/code then it may need changing, they sometimes re-start when cold with a faulty sensor, but its the luck of the draw.
    Jan 2010
    glasgow
    if its jumpt a tooth is would prob still run but pure bad missfire sluggish etc where are you mate have you pluged opcom on it or was it a normal code reader? im sure some 1 will come along and point you in the rite direction if you think its a sensor change it if you were in glasgow mate i would put my op-com on it see what shows up
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Did the person who looked at the code 'clear it' ?, if the code was showing 'present' & it was cleared it wouldn't start in most cases anyway.
    Oct 2010
    scotland
    yeah codes cleared and tested again, neighbour along road has reader, not the hand held one but not sure what kind.... code was p0340, camshaft sensor (not faulty but something like recieving incorrect data i think) but my engine dont have can shaft sensor according to vx was told that a faulty crankshaft sensor could throw this up too
    by way am in dundee
    Jan 2010
    glasgow
    some time if the sensors gone it heats up and thats what causes it not to start some peeps try and cool them to see if it will fire you could go to your nearest maplins and buy a can of component freezer spray and spray some on it just the sensor mind and see if it will start
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by andyguthrie View Post
    by way am in dundee
    P0340 Camshaft Position Sensor Circuit Malfunction
    Regular Member johnynoi's Avatar
    Jun 2009
    Dundee
    Exactly what happened to mine, jumped a tooth and wouldn't start, ended up with a few new valves, pistons survived though. Still set me back a grand though
  1. Tell me I haven't jumped the gun here................
    By carperjake in forum Bodywork & Interior
    Last Post: 19th July 2012, 00:34
  2. Tooth ache
    By paulvectrac in forum General Chat
    Last Post: 23rd November 2010, 19:53
  3. Cam Chain on Signum jumped a tooth - FIXED!!!
    By H3MSY in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2009, 22:52
  4. tooth ache
    By bigron1988 in forum General Chat
    Last Post: 12th April 2009, 21:45
  5. Plasmas jumped straight into modding, forum to blame for it!
    By plasma in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2006, 09:26
