Thread: ECU Question
    Regular Member manimal's Avatar
    Grimsby uk
    Default ECU Question
    I am arranging for an ECU to be delivered,everything to get the car started for £135.
    Best price so far.
    Once i have fitted it, does it it need programming for it to start the car ?
    If so, does it have to be with a Tech 2 or can it be done with a unit from 'snap-on tools' ?
    Bristol
    Vehicle : CDTI 150
    Yes some programming will have to be done.
    The ECU will need advising of certain 'options' e.g. automatic or manual etc.
    Then there will be the need to program your VIN to the ECU (it needs to match whats in the other ECU.
    I've not used the Snap On tool, so not sure.
    But Tech 2 or Vaux/Op Com can do this.
    I know yours is to early to be a CDTI but for info a CDTI would need to have each of the injectors coded in
    Grimsby uk
    Than for the info.Mine is a 1.8 petrol.
    Where do i find the VIN ?
    Regular Member LADmachining's Avatar
    Hampshire
    Quote Originally Posted by manimal View Post
    On the V5 (registration document).
    On a sticker on the B-pillar (next to the drivers' seat)
    On the plate visible through the windscreen (passenger side)
    From one of the other control units (such as the CIM)
    Regular Member Kyser143's Avatar
    Bradford
    Hi mate could I ask where u got your ECU from I also am in need of one and mines a 1.8 aswell. I have checked with some places but they want ECU Part number but I can't see this on mine Is it underneath in which case how is an ECU Removed.
    Kent
    Trim : SRI
    Engine : 1.9 CDTI 150
    did you check to see if it had been reset by tech 2/opcom.
    if it has then you would need to program it to your car, if not you might need the original car pass code so you can reset it to work on your car and prog the new keys etc
    Grimsby uk
    Apparently the unit has been cleared.
    The problem i have is,i have had a different engine fitted in the past, so the VIN will be different. I've heard it is on the engine somewhere.....but where ?
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
