Thread: Removing the airbox assistance
    Sodding Typical on Sea
    Default Removing the airbox assistance
    I am going to be trying to fit the xenon's tomorrow if I take delivery of the car, and this time I was going to do it bumper in place, so wanted to lift the entire airbox out as I know at least one has done.
    Many thanks before I wade in and break something
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    It is not fixed in at it just sits on rubber blocks .
    All i do prior to removing the airbox is to remove the maf then remove your top air box cover remove filter then lift airbox from nearest to engine side to remove . to replace opposite but put some oil on the rubber fitting,s to aid instillation .
    and still loving it
    Thank you good sir!
    stockport
    Arrow
    Quote Originally Posted by bobssignum View Post
    But I also put some tape around the top edges where the filter sits,as,when I took the filter out,there were leaves and bits of debris stuck to it's underside.Also did the airbox mod while it was off!!.FELIXX.
    Quote Originally Posted by felixx View Post
    I plan to do the airbox mod on this car as well and will do it at the same time will hoover out the debris and generally give it a jolly good scrubbing - matron -
    stockport
    Quote Originally Posted by Derek Mc View Post
    I must admit that I was a little surprised to find thing stuck to the underside of the filter.Its a pipercross panel filter,and I never thought about things getting in from the sides.
    You tend to underestimate the pulling power and suction of that turbo!!.FELIXX.
    EVERYWHERE
    Unlike the standard filter, large airborne objects (Moths etc) tend to stick to the oil used on the so-called 'performance filters'.
    Quote Originally Posted by diesel dog View Post
    Stuck like a moth to a,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, errr cant think of a clean explanation Dog!
  1. Airbox mod.....part deux!!! (rip off of VXR280 airbox mod)
    By paul_sri150 in forum Diesel Engine related
    Last Post: 30th January 2012, 22:50
  2. tires?? help assistance
    By Ean in forum Handling & Braking
    Last Post: 23rd May 2009, 17:52
  3. VX Assistance during 3yr warranty
    By 67688c in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2008, 19:22
  4. removing airbox and water bottle!!!
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2007, 12:40
vectra c air box removal
how to remive airbox vectra c
