Results 1 to 10 of 13
Thread: Small GSi faults....
    Oct 2010
    Ayrshire
    Default Small GSi faults....
    Got a couple of electical gremlins to sort out, anyone had a problem with the electric mirror control switch? Mines will only move the mirrors left. UP DOWN and RIGHT it will not do, guessing it will have something to do with the actual switch to move the mirrors.....
    Also, the cruise control is iffy, it won't turn on all the time, it takes some fiddling about to get it on. Only a minor thing but would like to fix it....
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Check the clutch spring regarding the cruise control. easy test when driving is to lift the pedal with your foot and set it
    Oct 2010
    Ayrshire
    Quote Originally Posted by Keithy View Post
    Thanks, I'll give that a try tomorrow.
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Can you hear the motor working when your trying to adjust the mirrors? Maybe the actual mirror glass just needs refitting.
    Oct 2010
    Ayrshire
    Haven't acutally listened for that, I'll also give that a try today.
    Full Member Big Sig's Avatar
    Don't forget that on most models you need to have pressed the brake pedal before it will engage
    Oct 2010
    Ayrshire
    CC working fine now, just need to sort the mirrors now.
    Jan 2008
    Dundee
    What was the problem with the cc?
    Regular Member david.aka.judas's Avatar
    Suffolk
    please say because mines not working, I've cleaned the contacts, lifted the pedals, pressed the brake prior to setting and still no joy.
    my garage are going to replace the sim/cim pack foc.
    Chelmsford
    Quote Originally Posted by david.aka.judas View Post
    please say because mines not working, I've cleaned the contacts, lifted the pedals, pressed the brake prior to setting and still no joy..
    Same here, I cleaned the contacts on the stalk last night but still no luck, even when holding the clutch up.
  1. My new car faults!
    By ScottyV6 in forum Engine & Drivetrain
    Last Post: 26th September 2012, 22:09
  2. OP-COM faults
    By WoodleySaint in forum Vectra C / Signum Troubleshooting
    Last Post: 1st June 2012, 16:36
  3. HID faults - yes / no?
    By chewy71 in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2011, 14:51
  4. Vec c faults
    By Rickiek123 in forum Bodywork & Interior
    Last Post: 19th January 2009, 21:43
  5. Car Faults
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 22nd September 2007, 14:11
