Results 1 to 10 of 28
Thread: eberspacher - on vectra cdti
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    Default eberspacher - on vectra cdti
    Good afternoon people . My vectra cdti 2007 has a eberspacher diesel-varmer. Is it possible to mount a switch on this so it wont start just when I drive for very short trips? I think this make much soot on this small trip and get broken because of this.
    Please,if someone had experience with this, tell me. I cant make a switch on the fuse, then the board computer also fall out.
    Thanks for answer.
    Ket
    Aug 2010
    North of Norway
    Someone?
    Full Member Big Sig's Avatar
    What exactly does this do?
    Admin plasma's Avatar
    On the Forum
    321 Post(s)
    Engine : 150
    Mileage : 74000
    I believe its some type of diesel heater? or interior cabin heater?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Aug 2010
    North of Norway
    When the outside temperatur is under +3 deg the ree this one starts to make faster heat to cooling water. I also can start it with the remotecontrol and it will starts and heat the water and inside of the car. Doesent opel diesel in UK have this one?
    No we don't have a preheater like that at all. Just the glow plugs.
    On the Forum
    321 Post(s)
    Engine : 150
    Mileage : 74000
    Its soo cold over there that they have an aux heater which i think is electric? (maybe heating element?) so the cabin is nice and warm when they go out to it, think i recall seeing this on EPC/TIS
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    the eberspächer can be upgraden to a cabinwarmer . You just have to find a ebersprächer mecanic/dealer.
    As its actually a option to have fullheating.. if done properly, you will be abel to control/set timer via the GID/CID.
    Engine : 2.2 Direct
    Quote Originally Posted by plasma View Post
    That is tru, its made on the "newer" vectra Diesel also here in Denmark, heating element placed in the vents.
    Aug 2010
    North of Norway
    Its a heater that burns diesel, just like webasto. Its starts up when the enigne get starte at outside temp 3 degree or lower. I can also make it start with the remote control or to a clock-set by the board-somputer. Then it also start the fan inside the car so its getting warm inside. When I come and start up the car it is warm an the engine has temperatur so it starts easy. I tough every diesel in europa had this one. Its vere nice, but it starts automatic when its cold, and if I just make a short trip (5 min) its not burning clean and its make soot. So I want to have a switch so I can choose if it should start or not.
  1. What you know about Eberspacher Hydronic add on Heater D5WZ
    By kingarthas in forum Vectra C / Signum Troubleshooting
    Last Post: 26th December 2012, 19:27
  2. 1.9 Vectra CDTi 150 VS 2.0 CDTi 160 insignia Sri
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 11:38
  3. Vectra 1.9 CDTI Sri Versus 3.0 CDTI V6 Sri
    By collateral in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2009, 20:18
vectra c eberspacher wiring
vectra c eberspächer
eberspacher opel vectra c
eberspacher vectra c
