Thread: Limited power and slight missfire! Help!!
    Oct 2010
    sidcup
    Exclamation Limited power and slight missfire! Help!!
    hi guys
    ive got a signum 2.2 04 auto and im experiancing some problems the car splatters and missfires at the top end of the rev range this results in loss of power and limp mode sometimes!
    any ideas ?
    i have changed the plugs and tried a new coil pack neither make a diference! my throtel body is a lil dirty but nufink magor!
    many thanks
    chris
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    has this just started doing this or has it gradually got this bad.. Sounds a rather like a fueling issue to me, don't those engines suffer from fuel pump probs. how many miles has the car done
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    Fuel Pressure Regulator maybe. Do you get a spanner light? Can you get fault code? If you dont have a code reader I think you can retrieve fault codes without a reader, somewhere on these forums explains how..
    Oct 2010
    sidcup
    hi guys the cars done 50,700 the prob just started! yes i get the spanner but wen i plug in it dosent say any codes!
    Oct 2010
    sidcup
    ir revs fine if i build up the revs slowly but missfires if its quick! it drives fine if u drive it like a granny but any sort of putting ur foot down and its just a gaint flat spot!
    Oct 2010
    sidcup
    hi guys thanks for all ur help had to bite the bulit today and put it into vaux! they said it will be £700 please for a new high pressure fule pump!
    fingers crossed this solves it!!
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    It will be the Pump mate same thing happend to mine buy the pump your self for £370 I think I payed and fit your self easy
    Sep 2010
    prestatyn
    Quote Originally Posted by x111pow-signum View Post
    hi there, it sounds like i have the same problem a you do you only get the problem when you accelerate? because when i drive like miss daisy i have no problem but when i push the pedal all my power disappears and it smokes, is this what's happening to you? if so then i know what i have to get to sort my problem. thanks steve
    Oct 2010
    sidcup
    hi steve yep exactly that! sean is it that easy?
    Apr 2008
    Liverpool
    Very easy about 10 15 mins 3 torx bolts holding the pump on to the engine then you just need to take the fuel line off the pump remember to depressurize the fuel line first by pushing the little nib in.
    you maybe able to get a pump cheaper then that the dealers will always have you off when it comes to these things
  1. slight Loss of power 1.9 cdti 2006
    By leedrummond in forum Engine & Drivetrain
    Last Post: 12th May 2012, 14:08
  2. slight lack of power
    By jay229 in forum Engine & Drivetrain
    Last Post: 30th May 2011, 12:30
  3. Slight Missfire/Judder
    By Tirfor in forum Engine & Drivetrain
    Last Post: 12th June 2010, 21:57
  4. Limited revs and power down
    By Ste in forum Engine & Drivetrain
    Last Post: 24th November 2009, 11:59
  5. Spanner light and slight loss of power 2.2dti
    By nickd_m in forum Engine & Drivetrain
    Last Post: 10th November 2008, 23:28
