Results 1 to 3 of 3
Thread: Spraying / Refurbishing Alloys
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Spraying / Refurbishing Alloys
    Up here I know of two companies who do it. One charges £150 per wheel and thats only for the face! (Lucky he is a garage and paintshop, he wouldn't get much business doing just wheels at that price!)
    The other charges £60 plus VAT per corner but have to take the wheel to him and leave for 24 hours! Not handy if your spare is a space saver!!
    Before I became enlightened, I was using an acid based wheel cleaner which has eroded the surface of the wheel and it is bubbling a bit so would like to get it sorted. Is it as simples as :
    Mask tyre
    Key alloy with sandpaper until flat
    1 undercoat
    2-3 silver
    2 lacquer?!
    Full Member gibbon7000's Avatar
    lincs
    Thats about it mate, rub down with 1200 between coats
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Admin plasma's Avatar
    On the Forum
    181 Post(s)
    Engine : 150
    Mileage : 74000
    Doing mine at this time, got lots of bad corrosion on the face and on the inside rim..
    Rubbing down with 80grit to remove corrosion. Filling any uneven bits with isopon, then using high build primer, then the usual wet'n'dry, colour and then lacquer
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
  1. Spraying Alloys
    By Cork1n in forum Styling
    Last Post: 18th February 2013, 12:41
  2. wheels refurbishing
    By the fisherman in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2009, 10:38
  3. Wheel Refurbishing.
    By BigMan in forum Styling
    Last Post: 16th July 2007, 11:56
