Results 1 to 10 of 21
Thread: Black soot/smoke when revving the engine
    Oct 2010
    hartlepool
    Default Black soot/smoke when revving the engine
    Hey guys, just joined up today for my girlfriend so go easy, had her vectra 2.2 dti for about 3 months now and recently we have just noticed that when revving the engine or putting your foot down the exhaust kicks out black smoke, when the car is idle and you rev it, it kicks out some soot on the floor.
    Ive read it could be numerous things but would anyone else know what the problem could be? Was reading it could be the EGR valve but maybe someone with a bit of knowledge would have a better understanding?
    Thanks very much.
    Sep 2010
    Hartlepool
    It might just be that it has always been driven "economically" which doesn't burn the soot up and get it out properly.
    I would be inclined to try giving it a good run up the A19 at high revs for a bit and see if it clears.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Are you losing boost ? or is the power down ?
    Nearly all diesels with chuck out black smoke when being revved hard its just a diesel thing like they say no poke without smoke
    But if your losing boost and its chucking loads of smoke out it could be boost pipes check these for cracks and holes
    Irmscher Insignia CDTI 130
    Oct 2010
    hartlepool
    Thans for the swift replies lads, The engine light has came on and the car slowed right down, I had to turn the ignition off and back on again for this to clear, ive tried taking it down the a19 today and it looks like the soot stopped but it then started up again aswell as the black smoke from the exhaust, how would I go about checking the boost pressure? Also I cant access the guide to checking the pipes as it says I dont have enough rights to do this?
    Really like this forum by the way, im sure ill be sticking around even tho its our lasses car, everyone seems friendly, unlike some other forums.
    Not too sure about the power being down as I only drive it now and again, how would I be able to tell? Doesnt help I have a faster car so it seems slower to me anyway.
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Quote Originally Posted by tigro View Post
    Hope this helps
    http://www.vectra-c.com/forum/showthread.php?t=115759
    Steve
    Huddersfield
    When was it last serviced. Black smoke usually means overfueling which can be too much fuel or not enough air to fuel mix. Check your air filter and have a look at all pipes to check for cracks in them. Best checking basics first.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    If engine light is on then you might be best to read codes this might be an easy way to tell what's wrong instead of guessing
    Oct 2010
    hartlepool
    Quote Originally Posted by Paulrushton View Post
    Been serviced every 12000 miles by vauxhall. Changed the air filter yesterday, ill get on with checking the pipes now as ive just finished de-tiling the kitchen
    Oct 2010
    hartlepool
    Ok guys im back, took the cover off the engine and found this
    http://img403.imageshack.us/i/dscf0255s.jpg
    http://img838.imageshack.us/i/dscf0256.jpg
    As you can see there is a big slice in the pipe im pointing at, what is this pipe? I did notice the engine bay was rather sooty im thinking this is due to this pipe? Another thing I noticed was when we revved the car the pipe im pointing too expanded and alot of air or fumes kept coming from it.
    Sorry cant get links to work. Copy and paste them into browser
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    cant see the pic mate
  1. Black soot around exaust pipe
    By TopRod in forum Detailing and Car Care Discussion
    Last Post: 5th July 2011, 11:04
  2. Black Soot Everywhere!
    By fattony in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2011, 14:17
  3. help please black smoke from engine
    By tigertye in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2011, 12:34
  4. black soot/smoke under heavy load
    By paul_sri150 in forum Diesel Engine related
    Last Post: 4th August 2010, 13:29
  5. engine chokes every now and again and black smoke problem
    By Paddyrallyhead in forum Engine & Drivetrain
    Last Post: 5th July 2010, 20:54
vectra has black soot from exhaust
black soot from exhaust on vectra
vauxhall vectra smokes on hard revving
ford courier black soot revving on revving
vectra c 1.9 black soot exhaust
black soot on reving hard mr2 mk3
vectra b black soot at muffler
diesel vauxhall sooted up engine
vauxhall vectra black sooty smokw
