Thread: Tyre Pressures - 1.9CDTi 150
    Regular Member Ross-SRi's Avatar
    Merseyside
    Default Tyre Pressures - 1.9CDTi 150
    Just a quicky... I've been inflating my tyres to 34psi, though I think this is a bit low.
    What would you guys say is the correct pressure to run at? About 36?
    I usually run with passengers, quite often a full load.
    Cheers in advance
    PRESTON
    36 psi will be fine, Vauxhall actually quote 38 psi as an eco setting to improve mpg.
    Merseyside
    Quote Originally Posted by barney490 View Post
    Thought so... Cheers!
    north east
    I run 35 all round .. might try 38 :-) cheers
    Liverpool
    i used to run 36 in front 34 in rear when i have 17's
    now running 39 / 38 in 19's
  1. tyre pressures
    By chewy71 in forum Vectra C / Signum Car Chat
    Last Post: 14th September 2011, 19:26
  2. Tyre pressures
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2010, 19:07
  3. Tyre Pressures
    By Tango in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2009, 00:10
  4. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  5. tyre Pressures
    By johnboycdti in forum Handling & Braking
    Last Post: 16th March 2006, 14:29
vauxhall vectra 1.9 cdti sri 150 tyre pressures
