Results 1 to 10 of 16
Thread: Exhaust possible MOT failure (help please).
    Mar 2007
    Hull
    Default Exhaust possible MOT failure (help please).
    Hi all, long time reader dont post much so would appreciate any help.
    Recently took my car to a friend of a friends garage for a service. Nice bloke been doing the car for a few years and never been a problem hes always honest and has your wallet in mind before doing work which isnt needed.
    I dropped the car off he give me a call alittle later explaining that a rubber pipe on my exhaust has split after the manifold and to replace would cost approx 80quid. I agreed to get work done as he explained it would be an MOT failure, so no probs. He called me back explaining that hes done a few of these on vectras and my exhaust setup is different to what hes seen (great!). He explained the part he ordered is a metal pipe into rubber pipe then back to metal with a connection to go on before the cat (manifold end). Hes taken mine off and there isnt a joint infact the cat is part of the pipe!
    He called the parts place and they quoted him 280quid which he said is expensive! He was honest and said if I shop around and look on the net I might find it cheaper and he appreciates that I would buy the cheaper and he would do the work when the MOT comes up for me.
    I dont actually know what the part is called and dont want to sound stupid when I call about. Does anybody know the name of the part which I am searching for and has anybody come across this before (vauxhall using different exhaust system setups on the same models)?
    Thanks guys and gals
    Rob
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    sounds like the flexi pipe is knackered, do you have a pic of the knackered section? What engine do you have?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by Caveman_nige View Post
    CDTi
    Mar 2007
    Hull
    sorry yeh I have the 1.9cdti 8v. can you not buy the flexi pipe seperate? haha. not been a cheapskate just had to find 800 quid for tyres and brakes and a new arm for our lasses astra since she insists on hitting speed bumps like a ramp.
    cheers.
    rob
    Vehicle : SRi
    Mileage : 137000
    There's clamp on ones on ebay or take it to an exhaust specialist and they will have an off the shelf one they can weld in.
    PRESTON
    could do with seeing a pic of the offending item. I cant think of any rubber pipe on the exhaust of a Veccy, maybe he is getting confused with the intercooler pipes as those are rubber and metal.
    Regular Member big nath's Avatar
    Jan 2008
    Irthlingborough
    Just had my flexi pipe replaced on my one today, Stealers wanted £710 for the front pipe fitted. So found a custom place in northampton who cut out old flexi and welded in new one and when they were there i had it de-cat so new pipe from front to middle cost £90.
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Had mine done, cost £32 in total owing to the fact that I have a 'tamed welder' available
    Jan 2008
    Irthlingborough
    Did you de-cat ? Sure it pick's up better now !
    Northampton
    Engine : A20DTH
    Mileage : 88000
    no rubber on the CDTi exhaust so not sure what going on here
  1. Did HID failure ever come in for MOT?
    By Ginge7289 in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2012, 13:58
  2. Mot failure
    By tangoman in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 1st June 2012, 20:59
  3. First MOT - anyone had a failure?
    By scarydeath in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2011, 09:28
  4. MOT Failure
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2008, 19:22
  5. mot failure?
    By leeandjude in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2007, 23:13
