Thread: Would This Fit ???
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Default Would This Fit ???
    aryt guys
    (52) plate vectra c 1.8 LS
    this clutch fit my veccy and is this a complete kit ?
    cheers guys
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...:X:RTQ:GB:1123
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    i thinks yours will have the dmf to change also.
    Your clutch on its way out?
    Aug 2010
    Dundee-Motherwell
    aryt keithy m8
    no sure if clutch needs changed or its just that dodgey spring on the pedal,just now and again its tight to go into gear,and sometimes hard to get outta gear
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    I did not think that the 1.8 petrol clutch unit if of the dual mass flywheel type. The Part No; for the complete clutch kit is 93185899 according to the forum. It may be a wise move to fit a new master cylinder at the same time.
    Jul 2009
    The Rift, Cardiff
    If its a bit stiff to get in and out of gear sometimes try a gear box oil change first. £4 for the final drive diff cover plate gasket and £12 for the oil from the stealers. The 1.8 doesn't have a dual mass fly wheel, it has a solid fly wheel.
