Results 1 to 10 of 22
Thread: Door loom
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Default Door loom
    Does anyone know which wire in the door loom becomes live when the door is opened?
    I.E The one that switches on the interior light when the door is opened
    Thanks in advance
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    I know the Gray/yellow that control illumination/dimming should become live.
    Jan 2008
    Dundee
    does that work the interior light rather than the window switches?
    Engine : 2.2 Direct
    The gray/yellow is the "dimming" bits for all switches.. i dont know what else color that becomes live in the door..
    Jan 2008
    Dundee
    so only when the door is open this wire becomes live. does it stay live until you shut the door or does it go off when the instruments go off?
    Engine : 2.2 Direct
    only til instruments go off
    Jan 2008
    Dundee
    aw thats a shame because the instruments are not always lit when opening the doors i.e when the engine is running ect
    Dunstable
    The grey / yellow wire is the switch illumination wire. It becomes live when the headlights are on or the door is opened, but only to illuminate the switches. Not sure what wire becomes live when the interior light is on if any
    Jan 2008
    Dundee
    this would make my mod so much easier if i could find a wire which would stay live for the duration the door is open
    Dunstable
    I don't see why there shouldn't be one. I don't even know where the door switch is that turns the interior light on. If you could find that then you can take a feed from that wether it's positive or negative, and add the permanent connection to the other contact on the light (opposite polarity to the door open contact)
  1. Door Loom
    By Das in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2011, 01:44
  2. Door loom.
    By MiniVauxhall in forum Electrical & ICE (including SatNav)
    Last Post: 14th November 2010, 22:08
  3. Rear door loom
    Last Post: 24th October 2010, 22:21
  4. Door loom question
    By Keithy in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2010, 21:43
  5. More Vec-B HELP!!! Door speaker loom soaked!
    By Vaux-Man-G in forum Electrical & ICE (including SatNav)
    Last Post: 16th May 2009, 19:30
