Thread: Is there an easy way to clean yor headlight lenses?.
    stockport
    Arrow Is there an easy way to clean yor headlight lenses?.
    I've just fitted a set of HID bulbs and they are great.However,because of the improved brightness,I have noticed that the bulb lenses are quite cloudy and wondered if anyone had a quick and easy solution for cleaning them.FELIXX.
    Regular Member Jezzy's Avatar
    S.E
    Sand them with wet'n'dry paper - which grade you use depends on how bad they are. 500 grit if they're bad, 1000 if they're not so bad. Either way, work your way up to 2000 or 2500 (might have to buy it online as it's hard to find on the high street), then use a cutting compound with a power tool (doing it by hand won't work as well), e.g. a cordless drill or a power polisher. Then polish by hand using normal car polish.
    stockport
    Arrow
    I was thinking more on the inside of the lens.The outside glass of the headlight seems fine,it's the inside of the bulb lens that seems to be very cloudy.FELIXX.
    S.E
    Do you mean the projector light itself, not the big clear cover?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by felixx View Post
    There not clear in the first place mate.
    stockport
    Arrow
    Thank's for that,I thought they were murky because of grime.(I don't suppose you really notice their clarity until you fit a better quality light!!!!).FELIXX.
    stockport
    Arrow
    I have just finished reading that post you started on HID headlights.
    Excellent information,it gives a very good explanation of how crap the standard lens fitment is compared to the HID system.Is there any way that a better lens could be fitted to an "04 Design" CDTI?.FELIXX.
    stockport
    Arrow
    By the way,I forgot to thank you for your input on my "problem".I had no idea that the headlight part I was talking about was a lens.I thought it had just gone cloudy!!!.
    I originally had the kit on a Mondeo and it was quite a lot brighter.I never even thought that there could be such a difference in a simple piece of standard equipment. FELIXX.
    stockport
    The last post was meant for your attention,sorry,FELIXX.
  1. Anyone used Tamron lenses
    By alcutler in forum Gen Photography
    Last Post: 24th December 2012, 15:03
  2. rear light lenses
    By djlee in forum Bodywork & Interior
    Last Post: 13th August 2011, 14:24
  3. Side Repeater Lenses...
    By Leemarksmith in forum Non Vectra C/Signum Album
    Last Post: 21st March 2010, 15:06
  4. Rear Lenses swap!!!! easy or not???
    By bigb1983 in forum Bodywork & Interior
    Last Post: 11th June 2009, 16:11
  5. Plastic welding headlight fixings - How easy?
    By Phil MC in forum Bodywork & Interior
    Last Post: 16th April 2009, 12:35
