Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: V6 3.0DCti Opinions
    Oct 2010
    Lincoln
    Default V6 3.0DCti Opinions
    Any gotchas with this engine. Thinking of either this or the 1.9 CDti 150 but have heard problems with the inlet manifold, egr and flywheel?
    Anything similar with the V6?
    Leicester
    I have had 4 1.9 CDTi's covering 30,000 miles a year and the engines have been perfect. My first CDTi 150 is still in the family, is 6 1/2 years old with 104000 miles on it and it is still running it's original DMF, EGR valve and inlet manifold.
    You will find there are far more 1.9's that have never had a problem than those that have.
    I have also had a 3.0 V6 CDTi Signum, and OK it sounds alot better than the 1.9 and it does go very well, it is a little lazier than the 1.9 but very very smooth.
    My 3.0 had a failed fuel pump that cost £2500 to replace, but this was covered by 888 as it just so happened to fail after they tried mapping it. So I would not let this worry you.
    If your not too worried about the lower average mpg, which in the real world on the 3.0 is going to be mid 30's going up in to the very low 40's if doing longer driving, then the 3.0 is a good option.
    The 1.9 is far quicker if re-mapped than the 3.0. All my 1.9's were re-mapped.
    There are plenty of 1.9's about so you can pick and choose.
    Sodding Typical on Sea
    The 3.0 is a glorious beast but at the economy range it offers, better thought would possibly be a 2.0 Turbo petrol. I went the 1.9 route and it is a typical 4 pot diesel bit rough (but remarkably quiet in a cruise and on the move) and even though I am no angel I still get over 50mpg
    The issues are there in the 3.0 as well especially the DMF they both have issues and both have benefit's. A tough call I appreciate.
    If you are after economy, including reduces insurance and wear / tear costs, then the 1.9 is for you
    If you are refined driving, with ease of acceleration for overtaking on country roads, then the 3.0 V6 CDTI is for you
    However, this will increase some costs slightly
    Apart from a blocked SCV (which also took the clutch a few weeks later) this engine has been flawless (compared to other VX engines I have had)
    You then have the usual Vectra C flaws, so you will get those no matter what engine it has
    Regular Member BigLad's Avatar
    Feb 2007
    30,000ft by day, bed at night
    Test drive both.
    1 is 'peaky' with lag/flat spots the other is lag free and smooth.
    You will buy the 3.0
    Quote Originally Posted by BigLad View Post
    Test drive both
    That's what I did, managed to find a dealership with three fairly identical cars, except for the engines, which allowed me to compare SRi trim level 1.8, 1.9 CDTI and V6 CDTI
    I then phoned my insurer at the time to see what they quote for all three types the difference was about £300 (before discount) between them, making an overall spread of about £30
    The dealership then phoned Retailer Warranties to see what the difference in cost for the warranty was, only to find the difference was by car and not engine, making the warranty the same cost for all three
    durham
    Trim : Leather
    yea drive them both and you will buy the v6 i drove the 1.9 then the 3.0 i bought the 3.0! says it all really, what an engine! not without issues mind you but what isnt.
    Oct 2010
    Lincoln
    Thanks guys, I'm gonna test drive the V6 tomorrow. What is the 'real' difference in mpg? Online shows about 10mpg less but is that in the real world?
    In real life from what I read in my research it is likely to pan out about 15>20mpg difference with a 3.0 to a 1.9
    Oct 2010
    Lincoln
    That much!! I average around 45 in my 2.0DTi so what am I going to go down to?
  1. Opinions Please!
    By spikeyboi33 in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2013, 20:35
  2. Opinions please
    By lencuff in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2010, 14:47
  3. opinions plz
    By kpf1grandprix in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2008, 21:18
  4. VX 220 opinions
    By steveked in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 13:55
  5. Your Opinions Please.....
    By P6UL K in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 29th February 2008, 12:21
