Results 1 to 10 of 11
Thread: recommended Gearbox specialist
    kent
    Default recommended Gearbox specialist
    Hi
    i need the 4th gear syncro replacing on my gearbox so im looking for a gearbox specialist in Kent/ Medway area or a garage that knows a bit about gearbox's
    Bret
    Regular Member RobertHayman's Avatar
    Sidmouth
    Vehicle : Insignia
    Engine : 2.0 CDTI auto
    Year : 63
    Mileage : 8,500
    Whats the mileage on this gearbox.
    My daughter had a Renault clio that was difficult to get in 1st and 2nd, and a gearbox specialist told me to change the gear oil and put in fully synthetic, as it was a common problem on the clio.
    I changed to fully synthetic and it improved. Takes a while for it to work around.
    kent
    the cars done 115000 miles, ive changed the oil to what vauxhall now specify but the problem is still there, the gears are crunching when changing from 5th to 4th. Been told by a couple or garages it could be the syncro or the selector fork.
    Want to try to find a reliable garage to properly diagnose it as ive been quoted £900+for a recon box and at that price i want to try to keep all my options open and see if the box could be repaired.
    Huddersfield
    Will it have syncro on 4th? My understanding was that it was only on 1st and 2nd or am I thinking older classics.
    kent
    I dont know the first thing about gearbox's, ive been told that they have them on all the gears except reverse
    Sidmouth
    Vehicle : Insignia
    Year : 63
    Mileage : 8,500
    Yea syncro on all gears. Have u tried blipping the throttle while the clutch is down to help match the shaft speeds while shifting from 5th to 4th.
    Do you have same problem going from 3rd to 4th ?
    kent
    no i haven't,will give it a try tomorrow. if im going below 35mph and then change down it's usually ok or if i go into 3rd then 4th its ok. No problems when changing up as long as im not driving it hard
    scotland
    might just be your clutch mate
    kent
    never thought of that,the biting point seems fine its not slipping. How would i test the clutch
    Sidmouth
    Vehicle : Insignia
    Year : 63
    Mileage : 8,500
    Quote Originally Posted by bret.c View Post
    Hand brake on, let the clutch up, should stall the engine.
  1. Automatic gearbox, recommended?
    By astradriver in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2013, 19:09
  2. Bumper specialist
    By the stig in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2011, 21:08
  3. vauxhall specialist in...
    By Swifty in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 4th October 2009, 12:10
  4. Can anyone recomend a good gearbox specialist in north west?
    By sri andy in forum Engine & Drivetrain
    Last Post: 24th August 2009, 20:33
  5. Specialist servicing
    By JonV6 in forum South Wales (RO - Vacant)
    Last Post: 8th January 2009, 20:00
