Thread: HandBrake Problem
    Regular Member Exclusive BV's Avatar
    West Midlands
    Default HandBrake Problem
    The Handbrake on my car is starting to play up.
    Most of the time I apply it and pull it up tight to it's normal level,
    But other times it goes slack and it goes up much higher and knocks the arm rest before going tight, but next time I use it it's back to normal again
    It's almost as if it's trying to auto adjust but keeps slipping back.
    It's not an immediate drama as I always park in gear but does anybody have an idea on whats happending.
    durham
    Trim : Leather
    I've just had to replace both rear callipers on mine as I had this problem about 1 year ago and never investigated it, hence new calipers now. I could be wrong but what you are describing is the first signs of the piston sticking , if it is it will only get worse then the wheels will drag and squeal . Hth
    Nottinghamshire
    Mine does the same. The Vectra C handbrake auto-adjusts every time you apply it via a mechanism under the handbrake lever. This can fail intermittently or completely. I can hear (and feel) a clunk as I pull the handbrake on the occasions where the auto-adjustment mechanism has failed and this is when the handbrake lever pulls up further as well.
    You can see if this is the problem by chocking the wheels, taking off the armrest, and then operating the handbrakes loads of times while keeping an eye on the auto-adjust mechanism underneath. You will see it slip when it fails and if this corresponds with the handbrake lever pulling up further than normal then that's your problem.
    If this is confirmed as the problem then the solution is to fit a new handbrake lever unit.
    Have a read of this...
    http://www.vectra-c.com/forum/showthread.php?t=93355
    West Midlands
    Cheers for the link.
    I think i'll take it into the dealer. Still got a Network Q warranty on it
    Hopefully this will be covered
    BTW when mine slips upwards it does not make any sounds or clonks.
    it just surprises me when it travels farther than it should.
    Nottinghamshire
    Quote Originally Posted by Exclusive BV View Post
    It's quite possible it's something else, but there's no point you spending time trying to find the problem as it should be covered by the warranty.
    Regular Member Dazzy2006's Avatar
    Notts
    - i also have exactly the same problem, let the dealer fix it under warranty as it needs a new handbrake assembly at about £130.00 plus the exhaust from the cat back has to come off to replace it
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    when i apply the brake pedal slighty and pull the handbrake it travels high and easy and holds. but if i dont press the pedal it takes about 6-7 clicks of the handbrake before it holds. Is this normal?
  1. Handbrake problem - advice please
    By silverman in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2013, 22:42
  2. Handbrake problem
    By Razzemup in forum Suspension, Wheels & Brakes
    Last Post: 23rd June 2012, 10:45
  3. Handbrake problem.......
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2009, 18:37
  4. Handbrake problem... another one for the list!
    By Jamie in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2008, 19:19
  5. That 'ol handbrake problem
    By purple170503 in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2007, 21:44
does my network q warranty cover the handbrake
handbrake needs pulling up further
vectra c handbrake problem
