Results 1 to 2 of 2
Thread: fan relay circuit 3
    corby
    Default fan relay circuit 3
    i have just had the car spanner light come on my 03 vectra, i had it diagnosed and it is, the fan relay circuit 3, how would i go about fixing this? any help would be appreciated
    milton keynes
    Quote Originally Posted by cruicky27 View Post
    This is saying your engine cooling fan is not working on the fastest setting , I had similar issues . Before you go and replace the cooling fans I would take the electrical connector of the cooling fans and spray with WD40 and the same with the engine ECU. The spraying the connections of the engine ECU fixed mine.
  1. Can you name that Relay?
    By Journeyman in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2016, 17:54
  2. P0615-02 Starter relay circuit voltage (fault code any help)
    By eaglepva in forum Engine & Drivetrain
    Last Post: 18th September 2011, 15:17
  3. A little help with the R7 relay
    By mofozo in forum Electrical & ICE (including SatNav)
    Last Post: 12th September 2011, 20:03
  4. Which Relay
    By manimal in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2010, 19:28
  5. Which relay is which?
    By JamesG in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2007, 19:18
vectra fan relay
vectra c engine fan relay
where is the fan relay on a vectra c
fan relay in vectra
