Thread: Outside air temperature fault
    Oct 2010
    WREXHAM
    Default Outside air temperature fault
    My temperature sensor was reading -40 degrees, so I have purchased a new sensor, but cant find the cable that plugs in to it. I can see where the sensor goes on the front grill, but there is no sign of the cable anywhere. Does anyone have any pictures or guide as where I can chase the cable from??
    The only cable I see in the area thats not plugged in to anything is a large plug about 30mm x 15mm which Im not sure what its for either??
    The car is a SXI but has a SRI front bumper fitted, but there seems to be no wiring for the spot lamps? did the SXI have spots originally?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Theres a big plug right hand side (passenger side) this should have a loom connected that goes to the centre of radiator/bumber this is the temp sensor.
    Im sure they did have fogs,the same loom that goes to your big plug has front fogs plugs on it too
    Irmscher Insignia CDTI 130
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    and this is the connector that the tempsensor (and front foglights (and front park pilot) goes to.
    Oct 2010
    WREXHAM
    Right I see the whole loom is missing then, if I was trying to get on from the scrappy, what would I need to ask for , cheers
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Have you got front fogs ? if you haven't and are planning to get them then i would get the full loom as the normal loom only has a plug for temp sensor
    Oct 2010
    WREXHAM
    Yes I do have the front fogs, so I will get the full loom, thanks
  1. Temperature help!!
    By Lex82 in forum Electrical & ICE (including SatNav)
    Last Post: 21st July 2012, 15:14
  2. Temperature changes
    By skene in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2012, 19:58
  3. No Outside Temperature.
    By lammy1961 in forum Insignia car chat
    Last Post: 30th January 2012, 15:58
  4. Replies: 15
    Last Post: 9th July 2011, 22:19
  5. max outside air temperature...
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2009, 11:03
