Results 1 to 10 of 15
Thread: Can i have a list?
    Regular Member Tonyl55's Avatar
    Sep 2010
    Norfolk
    Default Can i have a list?
    Can i have a list for everything i should be checking when going to look at a Vectra please? Is there anything special i need to check?
    How do i check if the CV Joints are gone? Will it be OK to take a jack with me to jack the car up and have a look underneath if i am thinking of putting down the deposit on it?
    Tony
    north east
    CVs you can check on a test drive, find a open space / park park turn full lock left and drive slow then full lock right drive slow if you hear knocking / clicking they need replacing.
    check all fluids, check the dash for any engine management lights, try the fans on all speeds (1234) if only 4 works it needs a new resister if none work you need a new fan.
    general body work just look over, check for broken springs front and rear.
    check tha thier is no grinding nosie when lifting the clutch (possible dmf failure)
    im sure somoen will add another 100 items soon
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    erm from me i would deffo check :
    water ingress in spare tyre well ,poor some water over the top of boot if hatchback and in each rear side gutter
    and rev engine out of gear see if you get a rattle from the clutch
    and if when you put it in first gear you dont get a slight pull forward
    take a look at the engine and see if swirl bar is in place
    these was just somethings i had to contend with
    these are easy and cheap to fix except the cluch as it can be a sign of DMF on its way out ,although mine was rattling for years
    i cant see it being a problem having a look underneath
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    Check the springs, front and rear, they like to break apparently...
    If you can, take a code reader with you too (though ask seller if he minds you plugging it in)
    Sep 2010
    Norfolk
    Thanks for advice people
    Would it be a good idea if they have got a ramp ask them if they can put it up on it so i can have a proper look under it?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    And check if the wiper linkages have been updated, if not insist they are.
    Gazza4
    Sep 2010
    Norfolk
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    How do i check for that mate?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Tonyl55 View Post
    The ball socket of the wiper linkage on the driver's side should be white (if you peer through the scuttle panel) if not it is the old linkage. Fail in that insist they have it change or get them to guarantee it has been changed if the car is out of warranty.
    Gazza4
    Sep 2010
    Norfolk
    Thanks for that mate, noted it down
    Regular Member Exclusive BV's Avatar
    West Midlands
    Different things to check for different engines.
    Which one are you looking at?
  1. another off , the list
    By biffbangpow in forum Vehicle Diaries
    Last Post: 3rd August 2012, 21:54
  2. Next wee mod off the list
    By m20_swe in forum Styling
    Last Post: 21st April 2012, 09:34
  3. Anything more to add to my to do list?
    By Dane-10 in forum General Motoring Chat
    Last Post: 8th March 2012, 09:43
  4. Your wish list?
    By V6 Turbo Elite in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2011, 15:43
  5. To Do List
    By shan in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2007, 17:01
