Thread: Flashing HIDS
    Regular Member paul4400's Avatar
    Lowestoft
    Thumbs up Flashing HIDS
    I have aftermarket Bosch HIDS fitted.
    Just recently the nearside one has started flashing and flickering, does anyone know if its going to be the ballistor or the bulb thats causing the problem? Have removed and checked all wiring and its all clean and tidy with no corrosion so suspect either of the above.
    Any ideas what to buy first, bulb or ballistor???
    This is not on the vectra its on our other car, looking at getting HIDS for the vectra and will be using HIDS Direct for that but need to get this other prob sorted first.
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    17 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 212,060
    Not heard of this and no expert on HIDs. It might be an idea to get in touch with HIDs Direct and ask them.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    Tech2 the UEC, change xenon light to present.
    Lowestoft
    Quote Originally Posted by yysnet View Post
    Its not on the vectra its on the Evo and its had them on for about 4 years with no probs until the last couple of weeks , removed it from the car sunday and checked all contacts were clean, put back again and it was still the same, only n/s one o/s one is fine.
    Thanks paul
    Huddersfield
    Try swapping the bulbs over and if it still flickers you know it's the ballast. If the bulb flickers in the other you know it's the bulb.
    Lowestoft
    Smile
    Will i have to do this when i fit HIDS to the vectra??? its a 06 exclusiv with sat nav, also how do i get the avg mpg/ fuel remaining reading to work as its not on my display ??
    Thanks paul
    Lowestoft
    Smile
    Quote Originally Posted by Paulrushton View Post
    Ok thanks, was hoping to get a answer lol as its a bast**d to get to, not as easy to work in the light area as it is on the vectra but will give it a try over the weekend, can then order a ballistor or bulb from hids direct to replace
    stockport
    Arrow
    Quote Originally Posted by paul4400 View Post
    I had this problem with the o/s headlight on my car so I fitted a canceler,which fits in line with the ballast and it stopped it.
    (Apparently,HID Direct supply them included in their kits),so if you are going to order a set from them,why not negotiate a price to include an extra set.You can also get them off eBay.I ordered my cancelers on the Sunday afternoon got them on the Tuesday!!.Best of luck. FELIXX.
  1. 3.2 EML flashing
    By DSmiddy in forum Engine & Drivetrain
    Last Post: 23rd February 2012, 10:02
  2. Finally stopped my hids from flashing
    By i5aces in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2011, 20:19
  3. flashing hid headlights
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2010, 01:25
  4. Flashing
    By Damian in forum The 'Off Topic' room
    Last Post: 2nd June 2009, 14:51
  5. MIL flashing
    By stevedee3 in forum Engine & Drivetrain
    Last Post: 22nd January 2007, 05:05
