Thread: preface steering wheel removal......
    newport
    Default preface steering wheel removal......
    does it need a puller? or is it just a case of undoing the torx screw and its 'loose'?
    Chelmsford
    a puller would probably be recommended, but i've always got away with a few light bangs from a mallet on any car I've worked on (not the Vec C though I might add)
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    it just pull's off no need for a hammer or anything
    Midlands Mod Shop - NFFC.
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    1) Switch on your ignition until all the dash lights come on but don't start the engine.
    2) With the ingnition on, disconnect the battery on both + & - terminals. By having the ingition on stops the alarm going off.
    4) Leave the car for about 10 minutes for the capacitance to drain from the airbag circuit.
    5) Half way down the steering wheel there is a hole in either side at the back, insert a small screw driver until you feel the metal plate, press inwards to release the airbag retaining clips, these are spring clips so will go back in place once you have removed the airbag. This may take a couple of attemps but it is easy once you have done the first.
    6) Undo the pink and yellow plugs for the air bag, and move the airbag to one side.
    7) Remove the main bolt from the middle of the steering wheel and gently pull off the steering wheel, you do not need a puller for this part of the job.
    8) Re-build in the reverse order of strip down.
    9) Re-connect the battery and all done.
    Edit:
    newport
    Quote Originally Posted by paulhb View Post
    Edit:
    top man! cheers!
    Chelmsford
    Whatever you do, do NOT reconnect the battery without the airbag fitted! Not that I've made that mistake myself of course...
    newport
    done a vec b one before but after the main nut was removed it needed a bit of 'gentle persuasion' with a hammer
  1. does a facelift sri steering wheel fit a preface sri?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2012, 15:27
  2. preface steering wheel and airbag change
    By taffy bhoy in forum Bodywork & Interior
    Last Post: 18th July 2011, 11:06
  3. scrollers on preface steering wheel - possible
    By NIGHTCD in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2011, 10:33
