So,
We have the following code on chrisvectra's Vec C 2005 CDTI 150:
B2966 - Driver Doorknob Circut Open or High Voltage
Any ideas what that refers too? Doorknob??
Weird one.. All works on the drivers door as it should
Baffled!!
A
So,
Baffled!!
A
for some reason that t/c is always stored in vectra's from 2005 onwards wouldn't worry about it if everything is working ok.
Yes its a commen error, have it on mine, after i changed my old door lock.
The old lock when pressed the pin, it locked all doors, the new lock dont. so its probaly a removal from facelift doorlocks. (mines a prefacelift, but new locks is replacement, and now just as the facelift)
when i push my drivers door button it only locks the drivers door
Agree.... My 05 full can car only locks the drivers door when the door pin is pushed down.
No issue then Chris
thats weird though init makes you wonder why they do it like that
