Thread: Fault Code on Vec C door module: B2966 - Driver Doorknob Circut Open or High Voltage
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Fault Code on Vec C door module: B2966 - Driver Doorknob Circut Open or High Voltage
    So,
    We have the following code on chrisvectra's Vec C 2005 CDTI 150:
    Any ideas what that refers too? Doorknob??
    Weird one.. All works on the drivers door as it should
    Baffled!!
    A
    Middlesex
    Trim : SRI
    Mileage : 100k
    Just found this :
    Quote Originally Posted by benny View Post
    the code for the door locks and windows beeing faulty are always present in a vec c ....some cars you find wont have them but the majority have ..just ignore the code .....do you have a fault ? ..
    So - looks like its a non issue Chris!
    Ive also read it can be where a door lock has been changed for a new type that doesnt support this perticular function..
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    for some reason that t/c is always stored in vectra's from 2005 onwards wouldn't worry about it if everything is working ok.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by paul wingnut View Post
    Nice one mate.. Confirms my thoughts
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Quote Originally Posted by AntSSSS View Post
    Just found this :
    thats good news fella
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Yes its a commen error, have it on mine, after i changed my old door lock.
    The old lock when pressed the pin, it locked all doors, the new lock dont. so its probaly a removal from facelift doorlocks. (mines a prefacelift, but new locks is replacement, and now just as the facelift)
    Are you VXR Enough
    13 Post(s)
    when i push my drivers door button it only locks the drivers door
    Engine : 2.2 Direct
    Yep because that "normal" but my old lock locked all..
    And i also got tha error when i changed the lock so its basic a designe change.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Agree.... My 05 full can car only locks the drivers door when the door pin is pushed down.
    No issue then Chris
    Are you VXR Enough
    13 Post(s)
    thats weird though init makes you wonder why they do it like that
  1. Instrument Dimming Bulb Output Circuit Open or High Voltage
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2016, 20:24
  2. b2966 driver doorknob circuit
    By 6009tristanb in forum Engine & Drivetrain
    Last Post: 27th January 2014, 18:08
  3. driver,s door closed but dash light says door is open
    By wulza in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2012, 01:47
  4. P0615-02 Starter relay circuit voltage (fault code any help)
    By eaglepva in forum Engine & Drivetrain
    Last Post: 18th September 2011, 15:17
  5. Driver door module advice needed..
    By j2cams in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2011, 22:16
b2966-05
b2966 Opel
Opel DTC B2966-05
Vauxhall DTC B2966-05
b2966-05 vectra ccar door fault on vectar cdtiVauxhall B2966Opel B2966vectra c b2966-05b2966vectra c door module need to be codedcoding a drivers side door module on a Vauxhall vectra cvectra c door module faultyvectra c door knob faultb2966-05 ошибка опель2966 05 vectra cOpel codigo B2966-05vectra c fault code B2966-05vectra fault code b2966 05 presentdoor knob open or high voltageb2966-05 signum problemedriver door knob circuit open or high voltageB2966-05 vectra problemb2966-05 vectraVauxhall vectra c door lock fault
