Results 1 to 10 of 14
Thread: Strut nightmare
    Chelmsford
    Default Strut nightmare
    Took one of my front struts off earlier to replace the coil spring.
    How on earth are you supposed to get the ****** top nut off?
    It's impossible to get a spanner on it (including swan-necks) and you can't get it with a socket as you have to hold the centre of the rod with a T50 whilst turning it.
    Anyone got any tips?
    Chelmsford
    Just checked the how2...
    The sparkplug socket method is what I've been doing, but my T-50 is nowhere near long enough to get to the rod through the socket...
    durham
    Trim : Leather
    hi mate know what you mean, i took my strut to a local friendly garage who put it in a vice and put the air tool on it and off she came, they are tight and i would not of got it off on my own! hth.
    Chelmsford
    Finally done it thank god!
    Had to wrap the jaws of my mole grips in rubber, grab the top of the strut (above the limit of what goes past the seals) and hold it tight while I got a socket on the top.
    I've mangled the torx slot on the rod quite badly so had to use the same method for tightening back up, but it seems to have done the job.
    milton keynes
    Vortex sockets is the way to go , I have used mine loads. It makes it so easy.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I bought a set of these for just this reason
    http://www.abbeypowertools.co.uk/sub...s-0001350.aspx
    They are excellent (if a little pricey) but they get the job done and you wouldn't believe how often you use them
    Regular Member Jezzy's Avatar
    S.E
    Isn't it best to crack the nut a little before you remove it from the car, i.e. whilst it's still held in situ?
    Chelmsford
    Yep, wish I'd thought about that before!
    I've learnt my lesson and already cracked the nut for the other side while it's still in place!
    Full Member paul.sessions's Avatar
    leighton buzzard
    Quote Originally Posted by kman247 View Post
    i want one
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    I found this job fairly easy!, remove strut, put spring compressors on, wiz of with air gun no prob,
  1. Nightmare
    By marko1966 in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2012, 19:26
  2. ABS nightmare!!
    By jonno1103 in forum Introduce yourself.
    Last Post: 26th March 2011, 00:29
  3. Nightmare
    By craigmerry in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2008, 21:35
  4. Nightmare!
    By payney in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2006, 23:08
  5. Nightmare!
    By GARY3306 in forum General Chat
    Last Post: 11th June 2006, 08:34
