Thread: Brake line corrosion
    Northern ireland
    Default Brake line corrosion
    My car recently failed it's NCT (Irish version of MOT).
    Had a few faults like bushes, and window washer which are now sorted.
    But it also failed for "brake line/hose advanced corrosion, offside and offside front".
    Asked the guy in the parts shop what I would need and he didn't know.
    Anyone have an idea as I'm not that car savvy.
    Thanks in advance cause u guys are alway on the ball.
    It's a 2002 Vectra C, 1.8 sxi.
    Jul 2009
    The Rift, Cardiff
    I had the same with my golf's mot after it was parked up for a year.
    I just got under the car with a brass wire brush and gave them a clean, then a bit of wd40 on a cloth and rub them over. Passed the re-test with no problems.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    i replaced my brake hoses a couple of weeks ago to braided hoses but you can get genuine vx hoses from the dealer cheaper i guess... just ring a dealer, give him your car reg number and see what the prices are.. many of the online places like autovaux will be able to do the same if that easier..
    The brake lines themselves I am not sure about, mine a fine but i thing a couple of guys on here may have had issues with theirs... Hopefully they will see this and offer their advise..
    Chelmsford
    Not done them on my Vec, but brake lines tend to be pretty easy.
    Work out which lines need doing and estimate the length from the ABS pump to the connection to the hose.
    Then get to your local motor factors, most sell brake pipe by the metre. Get them to put the connectors on the ends for you (matter of seconds with a flange tool)
    It then a matter of taking the old pipe off and threading the new one through the same way, it will bend really easily by hand.
    After that it's just a matter of bleeding the system
  1. Brake Corrosion advisory
    By ChrisVec22 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2012, 20:55
  2. Brake line removal
    By mparks8590 in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2010, 17:47
  3. Goodridge brake line kit
    Last Post: 25th October 2009, 11:09
  4. Vectra Rear Hydraulic Brake Line Replacement ???
    By Markuk27 in forum Handling & Braking
    Last Post: 20th May 2009, 02:35
  5. Signum Brake Pipe Corrosion
    By Mr Magoo in forum Suspension, Wheels & Brakes
    Last Post: 29th April 2008, 20:02
vectra c brake lines
