Results 1 to 10 of 29
Thread: Cdti comes on boost then hesitates
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    Default Cdti comes on boost then hesitates
    Hi all, I have a Vectra C SRi CDTi 150, when you floor the throttle the engine comes on boost ok but when you hit around 2200 rpm it hesitates briefly before carrying on, this is more exaggerated in the higher gears particularly if coming up from lower revs where the hesitation lasts much longer and the car makes a droning noise. The inlet manifold, boost sensor and egr valve are new and I've examined the rubber vacuum pipes for leaks as much as possible, they sound like they are holding vacuum when removed. Is this hesitation normal? Any help greatly appreciated, Cheers, Gaz.
    preston
    if your at lower revs 800-1400 then ?? turbo lag might be an issue although not really hesitation more like swimming in treacle
    at higher revs then i'd initially say egr but its new so...have they updated the software??, there is a TIS field remedy about this
    otherwise i'd also check fuel filter and renew + try running a premium diesel fuel for a few tanks
    Jan 2010
    Cornwall
    It does seem like lag, just trying to establish whether all is ok, i fitted the egr so is there a software update? The fuel filter is new and I always use vpower diesel, just seems odd that it starts to boost then just dies before picking up again, cheers Gaz.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Are you getting symptoms like:
    http://www.vectra-c.com/forum/showthread.php?t=118784
    I ask as your profile says your CDTI 150 was registered in 2005.
    Gazza4
    Jan 2010
    Cornwall
    Haven't had any fault codes, although 'slight blip in power under hard acceleration' sounds about right, going to check it out anyway ta.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Gazza36 View Post
    Mine happened at constant speed or hard accelearation, gary it could just be an air leak in your case. Not enough to trigger the EML but enough to limit power. All I can say is keep an eye on it before any decision is made either way.
    Gazza4
    Jan 2010
    Cornwall
    Yep, an air leak is mentioned often, I've checked and the only possible issue is that where the rubber hose connects to the oil separator it doesn't seal properly but I didn't think it would matter? Besides the vacuum hoses where else could air be leaking? Ta.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Intercooler - mine done what yours done 18months ago, it started as a 'wee blip' then a loss of boost for 2-3seconds after 2,000rpm, then spanner light and limp mode. The intercooler had split and the car was chucking out black smoke heavily.
    Like I say keep an eye on it. For me to have my intercooler replaced it cost £470 - not at a dealer though.
    Gazza4
    Jan 2010
    Cornwall
    Ok, I suppose the only way to find out is take it out and have a look? Cheers, Gaz.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Yip m8 either way it will rule it out or find the culprit.
    Gazza4
  1. cdti boost gauge
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2012, 20:20
  2. v6 cdti boost
    By broad in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2012, 16:25
  3. Cdti boost guage
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 20th April 2010, 21:08
  4. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  5. 19 cdti boost problem
    By sri22dti in forum Engine & Drivetrain
    Last Post: 7th February 2009, 23:08
