Thread: Door alignment - How to adjust?
    Regular Member Innes's Avatar
    Plymouth
    Default Door alignment - How to adjust?
    My drivers-side rear passenger door is out of alignment to the the other doors. I think the previous owner must hace had a knock. I noticed after I had bought it back in February. I was a little annoyed that I hadn't spotted it at the time but the doors open and close ok and thought I'd get round to doing something about it eventually.
    Well here I am ready to align the door. Never done it before but I'm a fairly practical guy and thing I can see how to adjust it but thought I'd post up some pics and ask advise from anyone who has done it before:
    IF LOOSEN THIS SCREW WILL I BE ABLE TO MOVE THE LOWER PART OF THE PASSENGER DOOR INWARDS TO ALIGN WITH THE DRIVERSIDE DOOR?...
    Jan 2010
    York
    No.
    However, if you loosen the two screws on the hinge (just crack them off, not loosen fully off), you might get some play, enough to ease the bottom of the door in.
    Plymouth
    Do you mean the two bolts on the right of the last pic? Isn't that just holding the door to the hinge. I can see if I tighten them up it may pull the door in but not by loosening them up! Did I get the wrong end of the stick?
    Full Member paul.sessions's Avatar
    leighton buzzard
    the thing you have circled just allows you to take the door off the pins.. what pedro said undo other two bolt or four if there is two hinges and should be enough play in there to straighten up . a bit..
    Plymouth
    Has anyone else done this and can give me some hints and tips?
    Jan 2010
    York
    Like I said, and backed up by Paul, the only way to do it is to slacken off the 2 other screws on the bottom hinge (the ones you haven't circled) and push the door back in place and re-tighten.
    Being a "fairly practical" kinda guy, you'll find it a doddle.
  1. Handbrake? is it self adjust?
    By dave1419 in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2013, 12:31
  2. headlight adjust
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2012, 15:01
  3. Handbrake adjust
    By st2malo in forum Bodywork & Interior
    Last Post: 16th January 2011, 12:47
  4. how do i adjust my headlights??
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2010, 16:41
  5. Whats the best way to adjust a door ?
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2008, 22:22
vauxhall astra drivers door alignment
vectra c door adjustment
adjust Vauxhall doors
corsa c 2009 door alignment
apteczka zafira b
zafira b door adjustment
zafira c door alignment to catch
how do you adjust the rear passenger door on a 2007 vauxhall vectra c
adjust door 2008 vectra c
vauxhall door hinge adjust
