Results 1 to 10 of 11
Thread: DAB Radio advice
    Regular Member Richgb's Avatar
    Aug 2010
    Birmingham
    Default DAB Radio advice
    I have a 54 plate Design model Vectra with a factory fitted opera 40 sound system. When I switch from the FM radio to DAB I get the message 'DAB Box error' which I have always assumed was because a DAB box is an optional extra and was never fitted.
    I was at the dealers yesterday getting my handbrake sorted as a recall and they said it probably is fitted otherwise the option would be turned off on the radio but couldn't be sure unless they stripped the radio/aerial to find out. No way man.
    Does anyone know if there is an easier way to confirm if I have a DAB box fitted and if so what the likely problem is?
    Aug 2010
    Birmingham
    Anyone?
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Have you a pic of your aerial base ? it should be a big fat base this is for DAB,The DAB box is located behind glovebox not aerial base lol
    Irmscher Insignia CDTI 130
    Aug 2010
    Birmingham
    This is the aerial. I would say that was a DAB one?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    you seem to have DAB and your unit is faulty. It is situated behind the glovebox in the top right corner. Maybe someone has removed it???
    Aug 2010
    Birmingham
    Thanks for the info, I will try and have a look behind the glove box over the weekend. Fiddling about I noticed that I do briefly get a DAB radio station on initial turn on via the ignition but it only lasts for a few seconds and then 'DAB box error' pops up.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    It is possible that a software upgrade will sort it but you would have to enquire at the dealers. Also perhaps the leads are loose that plug into the box.
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Might be faulty there's one on eBay but I'm not 100% sure but I think there coded to car so you would need the security code from donor car
    Aug 2010
    Birmingham
    Does the glove box come out easy? It seems well fitted, it's even enclosed underneath...
    Just looked at the one on ebay, it's an option if mine is knackered.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Richgb View Post
    5 torx screws, 3 at the top behind the door and 2 below it, it then pulls out/drops down. Just make sure u disconnect the interior light as you pull it out
  1. wanting a new radio any advice
    By davedave in forum Electrical & ICE (including SatNav)
    Last Post: 6th January 2013, 10:59
  2. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  3. CB radio advice
    By SVAC in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2011, 23:22
  4. CB radio advice
    Last Post: 14th May 2011, 07:05
  5. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
vauxhall vectra radio says DAB box error www.vectra-c.com
