Thread: Can one rev a Diesel Vectra engine from under bonnet?
    May 2006
    scotland
    Default Can one rev a Diesel Vectra engine from under bonnet?
    All,
    I remember the days when throttles (well on petrols) used to have a throttle cable and you could move the throttle assembly by hand whilst you had your head under the raised bonnet thus causing the engine to rev. I have a CDTi, my question is, can you do this from this car or is it totally electronic and need someone to press the throttle pedel from within?
    thanks
    Sep 2010
    Hartlepool
    I think you need to have someone press the accelerator pedal for you.
    Throttle cables are a thing of the past and I believe (Someone please correct me if I'm wrong) that the throttle sequence is now all electronic.
    HTH
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    You can't rev a deisel under the bonnet as they are drive by wire, what's more the throttle flap doesn't govern the acceleration in a diesel, pressing the throttle pedal tells the ECU to allow more fuel into the cylinders. It has nothing to do with the throttle plate/body.
    Gazza4
    Regular Member Tonyl55's Avatar
    Sep 2010
    Norfolk
    Is this a bad thing or good thing? Can't understand how it would work without a Throttle cable?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Tonyl55 View Post
    Deisels can work on a variety of Air/Fuel mixtures (2:1 - 50:1) and therefore a throttle isn't needed. The only thing the plate does in a deisel engine is control emissions.
    Gazza4
    its done by a sensor on the acelerator pedal , and a signal is sent to the ecu and this then sends a signal to the engine to allow more fuel
    Aug 2010
    Leeds
    http://www.wisegeek.com/what-is-a-potentiometer.htm
    This is a Potentiometer basiclly a switch like a rotary switch or a sliding one that alter the resistence.
    london
    They are 'drive by wire'. no cable on petrol engines either (2.2),
    electronic signal is sent to the ecu on ' how much ' power is required.
  1. under bonnet pic (ENGINE - BLING0
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2011, 08:44
  2. Which diesel engine??
    By cornishtaz in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2010, 17:39
  3. Vectra 2.0 Diesel engine warning light
    By Biggus Shlongus in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2009, 19:11
how to rev a diesel under the bonnet
Has a vectra 2005 got an accelerator cable
how to rev diesel engine under bonnet
where is accelerator under the bonnet
