Thread: Vectra engine in Zafira?
    Oct 2010
    Grimsby
    Default Vectra engine in Zafira?
    My engine has gone again (2nd time in 7 months) and ive just bought a Vectra engine to replace it, its Z19DTH the 150 bhp 1.9 cdti engine but will it definately fit my Zafira? from what ive read on other forums the engines are the same, maybe the monts will be slightly different but im hopeing it will be a case of swapping them from my engine? I got this engine http://cgi.ebay.co.uk/2005-VAUXHALL-...item4cf2663fdf it comes with turbo and all because I was told that they think my turbo had gone, ive had a brand new fuel pump fitted at VX already before they realised my engine was totally knackered! so I will put that on the good engine and also my flywheel and clutch because that was replaced only about 1 year ago too, can anyone envisage any problems and will I need to do any codeing on the tech 2?
    Regular Member Jezzy's Avatar
    S.E
    Does it come with the ECU?
    Oct 2010
    Grimsby
    Doubt it, but ive got the car pass and codes for my car with it being the same engine why would I need the ecu from the vectra? surely the ecu would be different for the gearing fueling and all sorts of other things?
    sheffield
    The engine will fit straight in, you will have to change all the wireing loom, as your zaf may have a dpf, use your own flywheel and clutch as your box should be m32, and the vectra will have been an f40, check the injector rail as yours may be a single plug and the vectra one a twin plug, use your own ecu, no tech 2 needed for anything...hth.....allso use your own starter motor and alternator
    Oct 2010
    Grimsby
    Mine definately doesnt have a dpf, i will change the flywheel + clutch as they are less then 12 months old and the alternator is about 18 months,also chage the fuel pump as thats brand new and will change the egr as thats quite new and starter as u say, will have to check the loom though.
    Thanks for the help so far!
  1. EGR and MAF location on a DTI 2.0 Zafira engine....
    By ijk571 in forum Engine & Drivetrain
    Last Post: 4th June 2012, 13:10
  2. zafira engine same as vectra???????
    By billyvectra in forum Engine & Drivetrain
    Last Post: 30th March 2011, 17:10
  3. zafira to vectra
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2010, 22:36
  4. Zafira or Vectra
    By joewin1975 in forum General Chat
    Last Post: 22nd November 2008, 20:43
  5. zafira vs vectra
    By silky in forum General Chat
    Last Post: 1st November 2007, 12:05
