Thread: Lack of power...
    Dumfries and Galloway Scotland
    Default Lack of power...
    A bit of a problem, I have a 1.9 CDTI Estate which has now started to drive
    with only half power, it starts fine pulls fine for about 5 mins then the
    spanner light comes on and it pulls with half power. I have put a code reader on but there are no codes listed. If I then stop switch the engine off restart
    the light goes out and all is fine for 2-3 mins light comes back on and then
    again drives with only half power.
    I am not sure about this next bit, but I think it appears to be running hotter
    than normal according to the temp guage... but you know what it's like you
    start reading into things when you have a problem. Is there a sensor that
    tells the engine to produce half power if things start to get hot?
    Any help would be great.
    Sep 2010
    Hartlepool
    You could try checking the boost vacuum hoses and your turbo hose for any splits / perishing as a good start point as a split in either of these would severely reduce your car's performance.
    HTH
    Oct 2010
    hartlepool
    Did you find the problem with your car? Having similar problems with my girls 2.2 dti, when revving it puts black soot on the floor too.
    Sep 2010
    Hartlepool
    You could also try checking the connection to your coolant temperature sensor that is located down the right side of your engine.
    preston
    your running temp should be about 80-85
    if you've got estate consider DPF....it might need regen
    but in no particular order
    also
    check and clean egr, boost sensor, throttle body + MAF sensor
    check hoses ( boost / intercooler )
    Make sure you've had it serviced in terms of air filter / fuel filter....oil as well if your doing these anyway.
    glowplugs can be a problem this time of year but normally they would show up on first key turn
    How many miles on clock, what kind of diesel do you use? supermarket or premium?
    Thanks to everyone that responded and here is the latest, got the two
    Gaskets to clean the EGR on the weekend, but Friday I did a 60 Mile
    journey that I wasn't looking forward to, but to my suprise 40 miles in
    the Spanner Light went out and all went back to normal and has been
    ok since.
    Richya you mention "coolant temperature sensor" is there a test procedure
    for this and do you need to drain the coolant to change it?
    The reason I ask is the temp gauge reading has certainly changed between
    running fine and not, it only runs a fraction above the start line 70 and
    may touch 80 but then drops very quickly to 70 ish. Allways been like this
    and runs fine. During the problem it ran closer to 80 Degs.
    It seemed to be this hover around the 80 Degs and that caused the Spanner light to come on. What are your thoughts?
    Thanks again everyone
    preston
    temp will depend on what your doing
    mine runs 80-85 when on the go .....quickly
    90 when in standing traffic after a fast run with lots or revs
    70 - 75 or so, it can drop back that way if i take it really slow and keep revs low
    New Member jonski's Avatar
    Oct 2010
    Rotherham
    Hiya I have same problem as you lightfx, and now its getting annoying, took it to a garage he put diagnostics machine on it and said it may need complete new fuel system, but surely if the fuel system was knackered my car wouldn't drive at all....... I keep hearing about the vacuum hoses but don't know which ones they are....does anybody have any piccys of them so I can check them please....
    Jonski
    Sep 2010
    Hartlepool
    Jonski - Have a read of this.....
    http://www.vectra-c.com/forum/showth...ht=check+boost
    I replaced mine for 4mm blue silicone tube off eBay and it works great.
    Really easy to do too!
    HTH
    Lightfx - I changed the coolant temperature sensor a couple of weeks ago and is really easy to do.
    Part only costs around £9 for the dealers.
    Wait until your engine is cold with your car parked on a slight incline (To get coolant to run away from front of engine).
    Remove the connector (Located down the right hand side of the engine).
    Unscrew the coolant temp sensor and you lose a little bit of coolant (I wasn't bothered as it wasn't much and my car was getting Vx serviced shortly after anyway).
    Screw in your new coolant temp sensor nice and tight and re-connect the connector.
    All done.
    Took around 10 - 15 mins in total.
    HTH
  1. 1.9 120 Lack of power.
    By carling in forum Engine & Drivetrain
    Last Post: 29th January 2013, 19:25
  2. lack of power
    By apache653 in forum Engine & Drivetrain
    Last Post: 16th February 2011, 11:51
  3. lack of power
    Last Post: 6th February 2011, 20:18
  4. Lack of Power
    By juggernaut in forum Engine & Drivetrain
    Last Post: 3rd April 2010, 16:20
  5. lack of power
    By astratovectra in forum Engine & Drivetrain
    Last Post: 20th February 2010, 19:56
